Salta al contenuto principale
iPod Mini Casing Replacement
Cosa ti serve
    1. iPod Mini Casing Replacement, Top Bezel: passo 1, immagine 1 di 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Mini Casing Replacement: passo 2, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Mini Casing Replacement: passo 3, immagine 1 di 1
      • Lift the top bezel off of the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Mini Casing Replacement, Bottom Bezel: passo 4, immagine 1 di 1
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Mini Casing Replacement: passo 5, immagine 1 di 1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Mini Casing Replacement: passo 6, immagine 1 di 1
      • Lift the metal retaining bracket out of the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPod Mini Casing Replacement, Casing: passo 7, immagine 1 di 1
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPod Mini Casing Replacement: passo 8, immagine 1 di 1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPod Mini Casing Replacement: passo 9, immagine 1 di 1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPod Mini Casing Replacement: passo 10, immagine 1 di 1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPod Mini Casing Replacement: passo 11, immagine 1 di 1
      • Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPod Mini Casing Replacement: passo 12, immagine 1 di 1
      • Continue to pull back on the black plastic tab and use your other hand to press down on the click wheel and begin to slide it out of the iPod.
      • It's important to press down on the click wheel as you slide it out, otherwise the click wheel could be scratched by the iPod's metal casing.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPod Mini Casing Replacement: passo 13, immagine 1 di 1
      • Continue to slide the click wheel out until it is free of the iPod.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPod Mini Casing Replacement: passo 14, immagine 1 di 1
      • Exterior casing remains.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 24 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
4Commenti sulla guida
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
kolbyhardy - Rispondi Condividi
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
Crystal Haugh - Rispondi Condividi
dude the pod mini is an mp3 player from 2005 it literally does not matter, plus, you probably &&^&@@ up the repair anyways
Memez_idk - Rispondi Condividi
@kolbyhardy He didn't touch your ipod mini. Anything you did to it is YOUR fault, not anyone else's, own your mistakes.
Cactus12 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 46
Ultimi 30 giorni: 174
Tutti i Tempi: 30,880
