Introduzione
Use this guide to restore silent alerts and replace a faulty vibrator in your iPhone 6.
This guide instructs you to detach the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while removing the vibrator motor from the iPhone, you can skip the display removal and go directly to the vibrator motor removal steps.
Cosa ti serve
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Attrezzo utilizzato in questo passaggio:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home buttonโone on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Remove the two 1.6 mm Phillips #00 screws securing the vibrator to the rear case.
Altre 62 persone hanno completato questa guida.
8 Commenti
Why do I need to remove the screen if the vibration device is in the open side of the iPhone ? Can't I just leave the screen connected and replace the vibrator ??
You can certainly do that! We added a note to the introduction to make that more clear.
You know that feeds the vibrator voltage?
Even with the battery off?
