Introduzione
Use this guide to replace the 5GHz Wi-Fi antenna.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
Close the handle on the iSclack, opening the suction cup jaws.
Place the bottom of your iPhone in between the suction cups.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following screws securing the antenna bracket to the rear case:
One 1.5 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
Altre 86 persone hanno completato questa guida.
20 Commenti
My wifi toggle is grayed out and my bluetooth wont turn on. Is this what I need to follow to get it working? I saw there was another part for wifi and bluetooth in the store.
Is it possible to swap wifi/bluetooth antenna from my old iphone 5 to iphone 6 plus?
No. iPhone parts are not interchangeable.
Tom Chai -
I notice that there are people who believe that this is the celular antenna but is not. This is the Wi-Fi antenna.
What happens when you forget the washer on the top left of the antenna?
