Introduzione
Use this guide to replace one or both speakers in your iPad mini 6.
You'll need replacement adhesive in order to complete this repair.
Cosa ti serve
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Passo 2 Heat the bottom edge
Attenzione: i passaggi 2-13 provengono da una guida contrassegnata come in corso.
Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
While you're waiting for the adhesive to loosen, note the following:
The areas at the top and bottom of the screen are sensitive to prying.
There's a long circuit board attached to the screen that sits parallel to the left edge.
Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap between the frame and the screen.
Leave the opening pick in place to prevent the adhesive from resealing.
Slide the pick along the bottom edge of the device towards the bottom-right corner.
Leave the pick in to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
Rotate the opening pick around the bottom-right corner of the device.
Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
Rest the screen upside down and parallel to the frame before continuing.
Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
Use tweezers, or your fingers, to remove the display cable bracket from the frame.
Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
Passo 15 Speaker information
Attenzione: il passaggio 15 proviene da una guida contrassegnata come in corso.
Passo 16 Unfasten the front camera shield
Attenzione: i passaggi 16-26 provengono da una guida contrassegnata come in corso.
Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
Use tweezers, or your fingers, to remove the front camera shield.
Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
Use the point of spudger to pry up and disconnect the top speaker's cable.
Gently peel back the cable to separate it from the frame.
Apply a heated iOpener to the top-left edge of the device for 90 seconds to loosen the top speaker's adhesive.
Adhesive is located around the perimeter of the speaker.
Adhesive is also located in the center of the speaker.
Insert an opening pick between the top speaker and the frame.
Pry up with the opening pick to completely separate the top speaker from the frame.
Remove the top speaker.
Passo 27 Disconnect the bottom speaker
Attenzione: i passaggi 27-32 provengono da una guida contrassegnata come in corso.
Use the point of spudger to pry up and disconnect the bottom speaker's cable.
Apply a heated iOpener to the bottom-left edge of the device to loosen the bottom speaker's adhesive.
Insert an opening pick between the bottom speaker and the frame.
Pry up with the opening pick to completely separate the bottom speaker from the frame.
Remove the bottom speaker.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
