Salta al contenuto principale
iPad 2 GSM Front Panel Replacement
Cosa ti serve
    1. iPad 2 GSM Front Panel Replacement, iOpener Heating: passo 1, immagine 1 di 2 iPad 2 GSM Front Panel Replacement, iOpener Heating: passo 1, immagine 2 di 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 2, immagine 1 di 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad 2 GSM Front Panel Replacement: passo 3, immagine 1 di 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad 2 GSM Front Panel Replacement, Alternate iOpener heating method: passo 4, immagine 1 di 2 iPad 2 GSM Front Panel Replacement, Alternate iOpener heating method: passo 4, immagine 2 di 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, Front Panel: passo 5, immagine 1 di 3 iPad 2 GSM Front Panel Replacement, Front Panel: passo 5, immagine 2 di 3 iPad 2 GSM Front Panel Replacement, Front Panel: passo 5, immagine 3 di 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 6, immagine 1 di 1
      • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
      • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
      • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad 2 GSM Front Panel Replacement: passo 7, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 7, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 7, immagine 3 di 3
      • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
      • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
      • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad 2 GSM Front Panel Replacement: passo 8, immagine 1 di 1
      • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad 2 GSM Front Panel Replacement: passo 9, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 9, immagine 2 di 2
      • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad 2 GSM Front Panel Replacement: passo 10, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 10, immagine 2 di 2
      • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad 2 GSM Front Panel Replacement: passo 11, immagine 1 di 1
      • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad 2 GSM Front Panel Replacement: passo 12, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 12, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 12, immagine 3 di 3
      • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
      • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
      • The adhesive is very strong, and some serious force may be required. Work carefully.
      • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad 2 GSM Front Panel Replacement: passo 13, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 13, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 13, immagine 3 di 3
      • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    10. iPad 2 GSM Front Panel Replacement: passo 14, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 14, immagine 2 di 2
      • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
      • Re-heat the iOpener, and move it to the top edge of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    11. iPad 2 GSM Front Panel Replacement: passo 15, immagine 1 di 1
      • The next few steps require extreme caution.
      • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
      • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
      Chiedi a FixBot
      Aggiungi Commento
    12. iPad 2 GSM Front Panel Replacement: passo 16, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 16, immagine 2 di 2
      • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
      • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
      Chiedi a FixBot
      Aggiungi Commento
    13. iPad 2 GSM Front Panel Replacement: passo 17, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 17, immagine 2 di 2
      • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
      • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
      • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
      Chiedi a FixBot
      Aggiungi Commento
    14. iPad 2 GSM Front Panel Replacement: passo 18, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 18, immagine 2 di 2
      • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
      • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
      • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
      Chiedi a FixBot
      Aggiungi Commento
    15. iPad 2 GSM Front Panel Replacement: passo 19, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 19, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 19, immagine 3 di 3
      • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
      • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
      • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
      Chiedi a FixBot
      Aggiungi Commento
    16. iPad 2 GSM Front Panel Replacement: passo 20, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 20, immagine 2 di 2
      • Continue releasing the adhesive all the way along the bottom edge of the iPad.
      • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
      • Leave the opening pick wedged underneath the front glass near the home button.
      Chiedi a FixBot
      Aggiungi Commento
    17. iPad 2 GSM Front Panel Replacement: passo 21, immagine 1 di 1
      • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
      Chiedi a FixBot
      Aggiungi Commento
    18. iPad 2 GSM Front Panel Replacement: passo 22, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 22, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 22, immagine 3 di 3
      • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
      • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
      • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
      • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
      Chiedi a FixBot
      Aggiungi Commento
    19. iPad 2 GSM Front Panel Replacement: passo 23, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 23, immagine 2 di 2
      • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
      • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
      Chiedi a FixBot
      Aggiungi Commento
    20. iPad 2 GSM Front Panel Replacement: passo 24, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 24, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 24, immagine 3 di 3
      • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
      • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    21. iPad 2 GSM Front Panel Replacement: passo 25, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 25, immagine 2 di 2
      • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
      • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
      Chiedi a FixBot
      Aggiungi Commento
    22. iPad 2 GSM Front Panel Replacement: passo 26, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 26, immagine 2 di 2
      • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
      • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    23. iPad 2 GSM Front Panel Replacement: passo 27, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 27, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      Microfiber Cleaning Cloths
      $3.99
      • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
      • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
      • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, LCD: passo 28, immagine 1 di 1
      • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 29, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 29, immagine 2 di 2
      • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
      • Lay the LCD on the front panel as seen in the second picture.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, Front Panel Assembly: passo 30, immagine 1 di 2 iPad 2 GSM Front Panel Replacement, Front Panel Assembly: passo 30, immagine 2 di 2
      • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
      • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
      • The retaining flaps are highlighted in red in the second picture.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 31, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 31, immagine 2 di 2
      • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
      • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad 2 GSM Front Panel Replacement: passo 32, immagine 1 di 1
      • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad 2 GSM Front Panel Replacement: passo 33, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 33, immagine 2 di 2
      • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
      • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
      • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
      • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
      • Set the LCD back into the body for safekeeping.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, Home Button Assembly: passo 34, immagine 1 di 1
      • The home button assembly is attached to the front panel with some adhesive. The use of an iOpener to soften the adhesive is highly recommended.
      • Place the iOpener in the microwave and microwave it for thirty seconds on the highest power setting.
      • Be careful not to overheat the iOpener during the repair procedure. We recommend waiting at least three minutes before reheating the iOpener.
      • Place the iOpener over the home button on the front edge of the display.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 35, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 35, immagine 2 di 2
      • Wedge the plastic opening tool under the right side of the home button assembly and pry upwards, releasing the adhesive on that side.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad 2 GSM Front Panel Replacement: passo 36, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 36, immagine 2 di 2
      • Using the technique above, release the adhesive on the left side of the home button.
      • Lift the home button mount off of the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad 2 GSM Front Panel Replacement: passo 37, immagine 1 di 3 iPad 2 GSM Front Panel Replacement: passo 37, immagine 2 di 3 iPad 2 GSM Front Panel Replacement: passo 37, immagine 3 di 3
      • Insert the edge of plastic opening tool underneath the edge of the home button mounting bracket.
      • Slide the plastic opening tool along the retaining spring bracket, releasing the adhesive.
      • Remove the home button with mounting bracket from the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, Camera Bracket: passo 38, immagine 1 di 1
      • The camera bracket is attached to the front panel by adhesive. The use of an iOpener to soften the adhesive is highly recommended.
      • Follow the iOpener heating instructions described in the iOpener heating section at the beginning of this guide.
      • Be careful not to overheat the iOpener during the repair procedure. We recommend waiting at least two minutes before reheating the iOpener.
      • Place the iOpener over the front facing camera on the front edge of the top of the display.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad 2 GSM Front Panel Replacement: passo 39, immagine 1 di 2 iPad 2 GSM Front Panel Replacement: passo 39, immagine 2 di 2
      • Use the flat end of a spudger to push the camera bracket off the adhesive securing it to the front panel.
      • The camera bracket will move about 2 mm to the right or left depending which way you push the camera bracket.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad 2 GSM Front Panel Replacement: passo 40, immagine 1 di 1
      • Lift and remove the camera bracket up off the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad 2 GSM Front Panel Replacement, Front Panel: passo 41, immagine 1 di 1
      • Front panel remains.
      • If you are replacing your panel with a new one, be aware that the new panel may have a protective film on the outside and/or inside of the frame. This needs to be removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these directions in reverse and use our iPad 2 GSM Front Panel Adhesive strips guide to reattach the front panel.
Altre 179 persone hanno completato questa guida.
9Commenti sulla guida
I would recommend that in cases of replacing shattered screens, that you tape the front panel glass with clear packing tape using overlapping strips, before you begin. This helps to ensure that the panel stays intact, and reduces the chances of puncturing the digitizing layer, and damaging the LCD upon removal.
You want to use clear tape so that you are able to see how any of the glass remnants are shifting during removal.
dcorsivo - Rispondi Condividi
Great job and tips as well
Oumar Mansare - Rispondi Condividi
Nice guide, easy to follow and along with the parts and correct tools, the replacement was a breeze.
Mike - Rispondi Condividi
Just so anyone knows attempting this its a mess of glass in most cases. keep a vacuum cleaner at arms length and were eye protection. And the caution about the wifi antenna is no joke. Thats a real ##&&% read it several times.
Daniel Magnusson - Rispondi Condividi
I had trouble with my iOpener and ended up using a heat gun, instead. It worked great, esp. with how shattered the glass was. It allowed me to heat only the area I was working on and made the process much faster. It still took me about 2 hours, but that's because I had a lot of little shards that I was trying to keep from ruining other components.
thewilkinsfam - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 27
Ultimi 30 giorni: 79
Tutti i Tempi: 107,000
