Salta al contenuto principale
iBook G3 Clamshell Display Replacement
Cosa ti serve
  1. iBook G3 Clamshell Display Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
    Chiedi a FixBot
    Aggiungi Commento
  2. iBook G3 Clamshell Display Replacement, Airport Card: passo 2, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
    Chiedi a FixBot
    Aggiungi Commento
  3. iBook G3 Clamshell Display Replacement: passo 3, immagine 1 di 1
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    Chiedi a FixBot
    Aggiungi Commento
  4. iBook G3 Clamshell Display Replacement: passo 4, immagine 1 di 1
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
    Chiedi a FixBot
    Aggiungi Commento
  5. iBook G3 Clamshell Display Replacement, Keyboard: passo 5, immagine 1 di 1
    • Remove the two Phillips screws that secure the RAM shield.
    Chiedi a FixBot
    Aggiungi Commento
  6. iBook G3 Clamshell Display Replacement: passo 6, immagine 1 di 1
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
    Chiedi a FixBot
    Aggiungi Commento
  7. iBook G3 Clamshell Display Replacement: passo 7, immagine 1 di 1
    • Pull up the keyboard connector cable by its clear plastic loop.
    Chiedi a FixBot
    Aggiungi Commento
  8. iBook G3 Clamshell Display Replacement, Upper Case: passo 8, immagine 1 di 1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
    Chiedi a FixBot
    Aggiungi Commento
  9. iBook G3 Clamshell Display Replacement: passo 9, immagine 1 di 1
    • Turn the computer over so that the bottom is facing up.
    • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
    Chiedi a FixBot
    Aggiungi Commento
  10. iBook G3 Clamshell Display Replacement: passo 10, immagine 1 di 1
    • Pull the CD-ROM drive tray partly out.
    • Remove the silver Phillips screw from the plastic casing.
    Chiedi a FixBot
    Aggiungi Commento
  11. iBook G3 Clamshell Display Replacement: passo 11, immagine 1 di 1
    • Turn the computer over.
    • Remove the three Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  12. iBook G3 Clamshell Display Replacement: passo 12, immagine 1 di 1
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  13. iBook G3 Clamshell Display Replacement: passo 13, immagine 1 di 1
    • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the clamp.
    Chiedi a FixBot
    Aggiungi Commento
  14. iBook G3 Clamshell Display Replacement: passo 14, immagine 1 di 1
    • Do not lift the upper case too far without first disconnecting the audio cable.
    • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
    • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
    Chiedi a FixBot
    Aggiungi Commento
  15. iBook G3 Clamshell Display Replacement: passo 15, immagine 1 di 1
    • Disconnect the audio cable.
    Chiedi a FixBot
    Aggiungi Commento
  16. iBook G3 Clamshell Display Replacement: passo 16, immagine 1 di 1
    • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
    • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
    Chiedi a FixBot
    Aggiungi Commento
  17. iBook G3 Clamshell Display Replacement, Modem: passo 17, immagine 1 di 1
    • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
    • Remove the EMI fingers.
    Chiedi a FixBot
    Aggiungi Commento
  18. iBook G3 Clamshell Display Replacement: passo 18, immagine 1 di 1
    • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
    Chiedi a FixBot
    Aggiungi Commento
  19. iBook G3 Clamshell Display Replacement: passo 19, immagine 1 di 1
    • Remove the Phillips screw from the left side of the modem.
    • Pry up the right side of the modem.
    Chiedi a FixBot
    Aggiungi Commento
  20. iBook G3 Clamshell Display Replacement: passo 20, immagine 1 di 1
    • Lift the modem partially out and disconnect the cable on the left side.
    Chiedi a FixBot
    Aggiungi Commento
  21. iBook G3 Clamshell Display Replacement, Display: passo 21, immagine 1 di 1
    • Remove the Phillips screw from the left hinge.
    • Peel up the airport cable from beneath the yellow tape.
    Chiedi a FixBot
    Aggiungi Commento
  22. iBook G3 Clamshell Display Replacement: passo 22, immagine 1 di 1
    • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
    Chiedi a FixBot
    Aggiungi Commento
  23. iBook G3 Clamshell Display Replacement: passo 23, immagine 1 di 1
    • Disconnect the backlight cable from the logic board and deroute it.
    Chiedi a FixBot
    Aggiungi Commento
  24. iBook G3 Clamshell Display Replacement: passo 24, immagine 1 di 1
    • Remove the three small Phillips screws from the clutch cover.
    Chiedi a FixBot
    Aggiungi Commento
  25. iBook G3 Clamshell Display Replacement: passo 25, immagine 1 di 1
    • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
    • Remove the display assembly.
    • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
2Commenti sulla guida
Veryinformativeandexcellentguideforibookclamshell.thankyou.
Renee Blakemore - Rispondi Condividi
Wait, so is the display the whole clamshell? There isn't steps to swap out the display inside the clamshell?
The Wonderer - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 23
Ultimi 30 giorni: 88
Tutti i Tempi: 18,906
