Salta al contenuto principale
iBook G3 12" RAM Replacement
Cosa ti serve
    1. iBook G3 12" RAM Replacement, Battery: passo 1, immagine 1 di 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Chiedi a FixBot
      Aggiungi Commento
    1. iBook G3 12" RAM Replacement, Keyboard: passo 2, immagine 1 di 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Chiedi a FixBot
      Aggiungi Commento
    2. iBook G3 12" RAM Replacement: passo 3, immagine 1 di 1
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      Chiedi a FixBot
      Aggiungi Commento
    3. iBook G3 12" RAM Replacement: passo 4, immagine 1 di 1
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      Chiedi a FixBot
      Aggiungi Commento
    4. iBook G3 12" RAM Replacement: passo 5, immagine 1 di 1
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      Chiedi a FixBot
      Aggiungi Commento
    5. iBook G3 12" RAM Replacement: passo 6, immagine 1 di 1
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      Chiedi a FixBot
      Aggiungi Commento
    6. iBook G3 12" RAM Replacement: passo 7, immagine 1 di 1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      Chiedi a FixBot
      Aggiungi Commento
    7. iBook G3 12" RAM Replacement: passo 8, immagine 1 di 1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      Chiedi a FixBot
      Aggiungi Commento
    1. iBook G3 12" RAM Replacement, RAM: passo 9, immagine 1 di 1
      • Your laptop should look approximately like this.
      Chiedi a FixBot
      Aggiungi Commento
    2. iBook G3 12" RAM Replacement: passo 10, immagine 1 di 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 47 persone hanno completato questa guida.
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 66
Tutti i Tempi: 34,730
