Salta al contenuto principale
iBook G3 12" Keyboard Replacement
Cosa ti serve
  1. iBook G3 12" Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. iBook G3 12" Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Chiedi a FixBot
    Aggiungi Commento
  3. iBook G3 12" Keyboard Replacement: passo 3, immagine 1 di 1
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    Chiedi a FixBot
    Aggiungi Commento
  4. iBook G3 12" Keyboard Replacement: passo 4, immagine 1 di 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    Chiedi a FixBot
    Aggiungi Commento
  5. iBook G3 12" Keyboard Replacement: passo 5, immagine 1 di 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    Chiedi a FixBot
    Aggiungi Commento
  6. iBook G3 12" Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    Chiedi a FixBot
    Aggiungi Commento
  7. iBook G3 12" Keyboard Replacement: passo 7, immagine 1 di 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Chiedi a FixBot
    Aggiungi Commento
  8. iBook G3 12" Keyboard Replacement: passo 8, immagine 1 di 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 17 persone hanno completato questa guida.
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 16
Ultimi 30 giorni: 57
Tutti i Tempi: 11,455
