Salta al contenuto principale
iBook G3 12" Display Replacement
Cosa ti serve
  1. iBook G3 12" Display Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. iBook G3 12" Display Replacement, Keyboard: passo 2, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Chiedi a FixBot
    Aggiungi Commento
  3. iBook G3 12" Display Replacement: passo 3, immagine 1 di 1
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    Chiedi a FixBot
    Aggiungi Commento
  4. iBook G3 12" Display Replacement: passo 4, immagine 1 di 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    Chiedi a FixBot
    Aggiungi Commento
  5. iBook G3 12" Display Replacement: passo 5, immagine 1 di 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    Chiedi a FixBot
    Aggiungi Commento
  6. iBook G3 12" Display Replacement: passo 6, immagine 1 di 1
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    Chiedi a FixBot
    Aggiungi Commento
  7. iBook G3 12" Display Replacement: passo 7, immagine 1 di 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Chiedi a FixBot
    Aggiungi Commento
  8. iBook G3 12" Display Replacement: passo 8, immagine 1 di 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Chiedi a FixBot
    Aggiungi Commento
  9. iBook G3 12" Display Replacement, Lower Case: passo 9, immagine 1 di 1
    • Your laptop should look approximately like this.
    Chiedi a FixBot
    Aggiungi Commento
  10. iBook G3 12" Display Replacement: passo 10, immagine 1 di 1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  11. iBook G3 12" Display Replacement: passo 11, immagine 1 di 1
    • Remove the three 5.2 mm newly-revealed Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  12. iBook G3 12" Display Replacement: passo 12, immagine 1 di 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    Chiedi a FixBot
    Aggiungi Commento
  13. iBook G3 12" Display Replacement: passo 13, immagine 1 di 1
    • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    Chiedi a FixBot
    Aggiungi Commento
  14. iBook G3 12" Display Replacement: passo 14, immagine 1 di 1
    • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
    Chiedi a FixBot
    Aggiungi Commento
  15. iBook G3 12" Display Replacement: passo 15, immagine 1 di 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  16. iBook G3 12" Display Replacement: passo 16, immagine 1 di 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    Chiedi a FixBot
    Aggiungi Commento
  17. iBook G3 12" Display Replacement: passo 17, immagine 1 di 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    Chiedi a FixBot
    Aggiungi Commento
  18. iBook G3 12" Display Replacement: passo 18, immagine 1 di 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    Chiedi a FixBot
    Aggiungi Commento
  19. iBook G3 12" Display Replacement: passo 19, immagine 1 di 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    Chiedi a FixBot
    Aggiungi Commento
  20. iBook G3 12" Display Replacement: passo 20, immagine 1 di 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Chiedi a FixBot
    Aggiungi Commento
  21. iBook G3 12" Display Replacement, Upper Case: passo 21, immagine 1 di 1
    • Remove the following 4 screws on the bottom of the computer:
    • Two 3 mm Phillips from the left side of the computer.
    • One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
    • One 14.2 mm Phillips near the front, right corner.
    Chiedi a FixBot
    Aggiungi Commento
  22. iBook G3 12" Display Replacement: passo 22, immagine 1 di 1
    • Use a straightened paperclip to open the optical drive tray.
    Chiedi a FixBot
    Aggiungi Commento
  23. iBook G3 12" Display Replacement: passo 23, immagine 1 di 1
    • Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  24. iBook G3 12" Display Replacement: passo 24, immagine 1 di 1
    • Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
    Chiedi a FixBot
    Aggiungi Commento
  25. iBook G3 12" Display Replacement: passo 25, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Turn over the computer and open it.
    • Use tweezers (or a refrigerator magnet) to remove the magnet covering a Phillips screw near the middle of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  26. iBook G3 12" Display Replacement: passo 26, immagine 1 di 1
    • Remove the following 4 screws on the edges of the keyboard area.
    • One 4.5 mm Phillips underneath where the magnet was.
    • Three 6 mm Phillips in plastic depressions.
    Chiedi a FixBot
    Aggiungi Commento
  27. iBook G3 12" Display Replacement: passo 27, immagine 1 di 1
    • Peel up the foil tape covering the speaker cable near the ports.
    Chiedi a FixBot
    Aggiungi Commento
  28. iBook G3 12" Display Replacement: passo 28, immagine 1 di 1
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  29. iBook G3 12" Display Replacement: passo 29, immagine 1 di 1
    • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  30. iBook G3 12" Display Replacement: passo 30, immagine 1 di 1
    • Before you can jerk the upper case off with joy, you must disconnect both the blue and white power cable and red and black speaker cable as described in the next steps.
    • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
    • There may be a thin metal bar fastened to the upper case by the two screws on either side of the optical drive. This bar provides rigidity around the optical drive; don't forget it when reassembling.
    Chiedi a FixBot
    Aggiungi Commento
  31. iBook G3 12" Display Replacement: passo 31, immagine 1 di 1
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
    Chiedi a FixBot
    Aggiungi Commento
  32. iBook G3 12" Display Replacement: passo 32, immagine 1 di 1
    • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    Chiedi a FixBot
    Aggiungi Commento
  33. iBook G3 12" Display Replacement: passo 33, immagine 1 di 1
    • There is a magnet that allows the computer to detect when the laptop is closed. If this magnet is not present your computer will not automatically go to sleep. Be sure the magnet is in the position indicated.
    Chiedi a FixBot
    Aggiungi Commento
  34. iBook G3 12" Display Replacement, Top Shield: passo 34, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  35. iBook G3 12" Display Replacement: passo 35, immagine 1 di 1
    • Remove the following 14 screws (some models may be missing a couple of screws):
    • One 2.5 mm Phillips.
    • Six 3.5 mm Phillips.
    • One 4.5 mm Phillips near the sleep light with a small shaft.
    • Two 4.5 mm Phillips with larger shafts.
    • Four 5 mm Phillips
    • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
    Chiedi a FixBot
    Aggiungi Commento
  36. iBook G3 12" Display Replacement: passo 36, immagine 1 di 1
    • Peel back three strips of yellow tape in the bottom left corner.
    • Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  37. iBook G3 12" Display Replacement: passo 37, immagine 1 di 1
    • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
    Chiedi a FixBot
    Aggiungi Commento
  38. iBook G3 12" Display Replacement, Display: passo 38, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  39. iBook G3 12" Display Replacement: passo 39, immagine 1 di 1
    • If you have already removed the hard drive in a previous step, your iBook may differ slightly from the picture.
    • Disconnect the microphone cable from the front, left corner of the logic board.
    • Peel back the black tape and free the microphone cable from the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  40. iBook G3 12" Display Replacement: passo 40, immagine 1 di 1
    • Use the black plastic handle to disconnect the display data cable from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  41. iBook G3 12" Display Replacement: passo 41, immagine 1 di 1
    • If you have already removed the modem in a previous step, you can skip this step.
    • Remove the single Phillips securing the display data cable to the metal framework.
    Chiedi a FixBot
    Aggiungi Commento
  42. iBook G3 12" Display Replacement: passo 42, immagine 1 di 1
    • Deroute the display data and microphone cables.
    Chiedi a FixBot
    Aggiungi Commento
  43. iBook G3 12" Display Replacement: passo 43, immagine 1 di 1
    • Peel back the yellow tape securing the inverter cable to the optical drive.
    Chiedi a FixBot
    Aggiungi Commento
  44. iBook G3 12" Display Replacement: passo 44, immagine 1 di 1
    • Disconnect the inverter cable from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  45. iBook G3 12" Display Replacement: passo 45, immagine 1 di 1
    • Carefully deroute the inverter cable from beneath the optical drive.
    • Deroute the Airport antenna cable from beneath the optical drive.
    Chiedi a FixBot
    Aggiungi Commento
  46. iBook G3 12" Display Replacement: passo 46, immagine 1 di 1
    • Support the display with your free hand while removing the following screws.
    • Remove the single Phillips screw on the outer edge of either hinge (two screws total).
    • Tilt the display back to get over two small nubbins, and then slide it directly from the case and away.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 29 persone hanno completato questa guida.
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 60
Tutti i Tempi: 36,075
