Salta al contenuto principale
Zune Flash 2nd Generation Back Cover Replacement
Cosa ti serve
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
    Chiedi a FixBot
    Aggiungi Commento
  2. Zune Flash 2nd Generation Back Cover Replacement: passo 2, immagine 1 di 2 Zune Flash 2nd Generation Back Cover Replacement: passo 2, immagine 2 di 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Zune Flash 2nd Generation Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 1 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 2 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 4, immagine 3 di 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 1 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 2 di 3 Zune Flash 2nd Generation Back Cover Replacement: passo 5, immagine 3 di 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
ybahman
Membro da: 11/01/09
139 Reputazione
4 guide realizzate
Cal Poly, Team 9-20, Regan Fall 2009 Membro di Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 43
Tutti i Tempi: 4,205
