Salta al contenuto principale
ZTE Whirl 2 Screen Replacement
Cosa ti serve
  1. ZTE Whirl 2 Screen Replacement, Battery: passo 1, immagine 1 di 3 ZTE Whirl 2 Screen Replacement, Battery: passo 1, immagine 2 di 3 ZTE Whirl 2 Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Screen Replacement: passo 2, immagine 1 di 3 ZTE Whirl 2 Screen Replacement: passo 2, immagine 2 di 3 ZTE Whirl 2 Screen Replacement: passo 2, immagine 3 di 3
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, immagine 1 di 3 ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, immagine 2 di 3 ZTE Whirl 2 Screen Replacement, Back Panel: passo 3, immagine 3 di 3
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Screen Replacement: passo 4, immagine 1 di 3 ZTE Whirl 2 Screen Replacement: passo 4, immagine 2 di 3 ZTE Whirl 2 Screen Replacement: passo 4, immagine 3 di 3
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Screen Replacement, Screen: passo 6, immagine 1 di 2 ZTE Whirl 2 Screen Replacement, Screen: passo 6, immagine 2 di 2
    • Use tweezers to pull the lock button and volume stickers out from the side panels.
    • Use the iFixit Opening Tool to unlock the ribbon connector above the camera. Pull the ribbon from the connector.
  7. ZTE Whirl 2 Screen Replacement: passo 7, immagine 1 di 1
    • Use a spudger tool to unlock the screen ribbon cable.
    • Pull the ribbon cable from the connecter with a pair of tweezers.
  8. ZTE Whirl 2 Screen Replacement: passo 8, immagine 1 di 3 ZTE Whirl 2 Screen Replacement: passo 8, immagine 2 di 3 ZTE Whirl 2 Screen Replacement: passo 8, immagine 3 di 3
    • Remove the motherboard to access the screen. Lift the screen away from the front cover and replace.
Conclusione
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Membro di UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 86
