Salta al contenuto principale
ZTE Prestige 2 Back Camera Replacement
Cosa ti serve
  1. ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, immagine 1 di 3 ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, immagine 2 di 3 ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, immagine 3 di 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
    Chiedi a FixBot
  2. ZTE Prestige 2 Back Camera Replacement: passo 2, immagine 1 di 2 ZTE Prestige 2 Back Camera Replacement: passo 2, immagine 2 di 2
    • Remove the battery.
    Chiedi a FixBot
  3. ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, immagine 1 di 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, immagine 2 di 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, immagine 3 di 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
    Chiedi a FixBot
  4. ZTE Prestige 2 Back Camera Replacement: passo 4, immagine 1 di 3 ZTE Prestige 2 Back Camera Replacement: passo 4, immagine 2 di 3 ZTE Prestige 2 Back Camera Replacement: passo 4, immagine 3 di 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
    Chiedi a FixBot
  5. ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, immagine 1 di 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, immagine 2 di 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, immagine 3 di 3
    • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
    • Remove the camera.
    • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
    • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
    Chiedi a FixBot
Conclusione
Maria Stock
Membro da: 01/31/20
524 Reputazione
5 guide realizzate
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Membro di UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 72
Tutti i Tempi: 443
