Salta al contenuto principale
ZTE Maven 3 Back Camera Replacement
Cosa ti serve
  1. ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, immagine 1 di 3 ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, immagine 2 di 3 ZTE Maven 3 Back Camera Replacement, Back Cover: passo 1, immagine 3 di 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    Chiedi a FixBot
    Aggiungi Commento
  2. ZTE Maven 3 Back Camera Replacement, Battery: passo 2, immagine 1 di 3 ZTE Maven 3 Back Camera Replacement, Battery: passo 2, immagine 2 di 3 ZTE Maven 3 Back Camera Replacement, Battery: passo 2, immagine 3 di 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. ZTE Maven 3 Back Camera Replacement, Midframe: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. ZTE Maven 3 Back Camera Replacement: passo 4, immagine 1 di 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    Chiedi a FixBot
    Aggiungi Commento
  5. ZTE Maven 3 Back Camera Replacement: passo 5, immagine 1 di 2 ZTE Maven 3 Back Camera Replacement: passo 5, immagine 2 di 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
    Chiedi a FixBot
    Aggiungi Commento
  6. ZTE Maven 3 Back Camera Replacement, Back Camera: passo 6, immagine 1 di 2 ZTE Maven 3 Back Camera Replacement, Back Camera: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Detach the ribbon cable connecting the camera in the top middle of the phone.
    • Use blunt tweezers to pull the camera off and put it aside.
    • Using this same method, grab the tweezers and insert the replacement camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 297
