Salta al contenuto principale
ZTE Compel Battery Replacement
Cosa ti serve
  1. ZTE Compel Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. ZTE Compel Battery Replacement: passo 2, immagine 1 di 1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
    Chiedi a FixBot
    Aggiungi Commento
  3. ZTE Compel Battery Replacement: passo 3, immagine 1 di 1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Ohio State, Team S1-G4, Whitney Fall 2018 Membro di Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 39
Tutti i Tempi: 480
