Salta al contenuto principale
Yuneec Typhoon Q500 4K Motor Replacement
Cosa ti serve
  1. Yuneec Typhoon Q500 4K Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Remove the propeller from the side where the motor is not working.
    • You can remove the propeller at any point in the replacement.
  2. Yuneec Typhoon Q500 4K Motor Replacement: passo 2, immagine 1 di 2 Yuneec Typhoon Q500 4K Motor Replacement: passo 2, immagine 2 di 2
    • Grab the motor with one hand and propeller with the other.
    • Turn the propeller counterclockwise to separate the propeller from the drone.
  3. Yuneec Typhoon Q500 4K Motor Replacement: passo 3, immagine 1 di 1
    • Flip the drone upside down.
  4. Yuneec Typhoon Q500 4K Motor Replacement: passo 4, immagine 1 di 3 Yuneec Typhoon Q500 4K Motor Replacement: passo 4, immagine 2 di 3 Yuneec Typhoon Q500 4K Motor Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #00 screwdriver and remove the four screws that secure the light cover.
  5. Yuneec Typhoon Q500 4K Motor Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to pry up and out the PCB.
  6. Yuneec Typhoon Q500 4K Motor Replacement: passo 6, immagine 1 di 2 Yuneec Typhoon Q500 4K Motor Replacement: passo 6, immagine 2 di 2
    • Use a 2mm Hex screwdriver to remove the four screws that are located below the PCB.
  7. Yuneec Typhoon Q500 4K Motor Replacement: passo 7, immagine 1 di 1
    • Flip the drone over then replace the motor with a new one.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Dev Panchal
Membro da: 10/30/24
680 Reputazione
5 Guide realizzate
Cuesta, Team 10-5, Krynen Fall 2024 Membro di Cuesta, Team 10-5, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G5
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 25
Tutti i Tempi: 105
