Salta al contenuto principale
Xiaomi Redmi Note Front-Facing Camera Replacement
Cosa ti serve
    1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: passo 1, immagine 1 di 1
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      Chiedi a FixBot
      Aggiungi Commento
    2. Xiaomi Redmi Note Front-Facing Camera Replacement: passo 2, immagine 1 di 2 Xiaomi Redmi Note Front-Facing Camera Replacement: passo 2, immagine 2 di 2
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Xiaomi Redmi Note Front-Facing Camera Replacement: passo 3, immagine 1 di 2 Xiaomi Redmi Note Front-Facing Camera Replacement: passo 3, immagine 2 di 2
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: passo 4, immagine 1 di 2 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: passo 4, immagine 2 di 2
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      Chiedi a FixBot
      Aggiungi Commento
    2. Xiaomi Redmi Note Front-Facing Camera Replacement: passo 5, immagine 1 di 2 Xiaomi Redmi Note Front-Facing Camera Replacement: passo 5, immagine 2 di 2
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      Chiedi a FixBot
      Aggiungi Commento
    1. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 1 di 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 2 di 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
      • Use tweezers to pull the ribbon cable out of the ZIF connector.
      • Remove the front-facing camera from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S22-G4, Livingston Spring 2017 Membro di Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Membri
32 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 37
Tutti i Tempi: 2,042
