Introduzione
Use this guide to remove and replace a broken or defective front camera in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Use a pair of tweezers to pell the copper tape off the motherboard and fold it out of the way.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
4 Commenti
Can you suggest a replacement Front camera where I can purchase?
Muchísimas gracias por la guía. Pude Limpiar la cámara frontal sin ningún problema.
Hello,
is there also a possibility to exchange a display on a Mi9?
Best Regards
Frank
Hi Frank,
this AMOLED & Digitizer guide might be the one you’re looking for.
