Salta al contenuto principale
Xbox Series X|S Controller (Model 1914) Back Housing Replacement
Cosa ti serve
  1. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: passo 1, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: passo 1, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the battery cover: passo 1, immagine 3 di 3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: passo 2, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: passo 2, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the batteries: passo 2, immagine 3 di 3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 3, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 3, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 3, immagine 3 di 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: passo 4, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: passo 4, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the left handle cover clips: passo 4, immagine 3 di 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: passo 5, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: passo 5, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the left handle cover: passo 5, immagine 3 di 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 6, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 6, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Insert an opening tool: passo 6, immagine 3 di 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: passo 7, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: passo 7, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Release the right handle cover clips: passo 7, immagine 3 di 3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: passo 8, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: passo 8, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the right handle cover: passo 8, immagine 3 di 3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: passo 9, immagine 1 di 2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Reposition the battery compartment sticker: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: passo 10, immagine 1 di 2 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Unfasten the top housing: passo 10, immagine 2 di 2
    • Use a Torx T8 Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: passo 11, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: passo 11, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the top housing: passo 11, immagine 3 di 3
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: passo 12, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: passo 12, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Pry up the midframe assembly: passo 12, immagine 3 di 3
    • Insert the flat end of a spudger into the rectangular gap between the midframe assembly and back housing, nearest the left bumper.
    • Twist the spudger to partially release the midframe assembly.
    • Repeat this prying procedure on the gap near the right bumper to completely release the midframe assembly.
  13. Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: passo 13, immagine 1 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: passo 13, immagine 2 di 3 Xbox Series X|S Controller (Model 1914) Back Housing Replacement, Remove the midframe assembly: passo 13, immagine 3 di 3
Conclusione
Altre 7 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
118 Membri
19.612 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 23
Ultimi 7 Giorni: 146
Ultimi 30 Giorni: 823
Tutti i Tempi: 11,208
