Salta al contenuto principale
Xbox One Wireless Controller D-Pad Replacement
Cosa ti serve
  1. Xbox One Wireless Controller D-Pad Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Remove the battery pack cover.
    • Remove batteries.
    Chiedi a FixBot
    Aggiungi Commento
  2. Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Side Handles: passo 2, immagine 2 di 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Chiedi a FixBot
    Aggiungi Commento
  3. Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Screws: passo 3, immagine 2 di 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Xbox One Wireless Controller D-Pad Replacement, Backplate: passo 4, immagine 1 di 1
    • Remove the backplate.
    Chiedi a FixBot
    Aggiungi Commento
  5. Xbox One Wireless Controller D-Pad Replacement, Faceplate: passo 5, immagine 1 di 1
    • Remove the faceplate.
    Chiedi a FixBot
    Aggiungi Commento
  6. Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, immagine 1 di 2 Xbox One Wireless Controller D-Pad Replacement, Metal Frame: passo 6, immagine 2 di 2
    • Pry off the metal frame around the D-Pad.
    Chiedi a FixBot
    Aggiungi Commento
  7. Xbox One Wireless Controller D-Pad Replacement, D-Pad: passo 7, immagine 1 di 1
    • Lift the D-Pad out of its housing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 50 persone hanno completato questa guida.
Cal Poly, Team 20-15, Maness Winter 2015 Membro di Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membri
54 guide realizzate
7Commenti sulla guida
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
Arief Hidayat - Rispondi Condividi
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon - Rispondi Condividi
it's exactly the same like shown above :)
David Schmidt - Rispondi Condividi
How do u fix one of the silver things behind the d-pad?
Bob - Rispondi Condividi
How do fix the silver things behind each d-pad
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 76
Ultimi 30 giorni: 328
Tutti i Tempi: 71,863
