Salta al contenuto principale
Xbox 360 S Heat Sink Replacement
Cosa ti serve
  1. Xbox 360 S Heat Sink Replacement, Top Panel: passo 1, immagine 1 di 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Heat Sink Replacement: passo 2, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 2, immagine 2 di 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
    Whoever gave that tool the name “spudger” needs to be shot in the face.
    Richard - Replica
    This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
    TheSupport - Replica
  3. Xbox 360 S Heat Sink Replacement: passo 3, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 3, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 3, immagine 3 di 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Heat Sink Replacement: passo 4, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 4, immagine 2 di 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Heat Sink Replacement: passo 5, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 5, immagine 2 di 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
    see the red boxes specially in image
    Restrict - Replica
  6. Xbox 360 S Heat Sink Replacement: passo 6, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 6, immagine 2 di 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
    So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
    HumidTater - Replica
  7. Xbox 360 S Heat Sink Replacement: passo 7, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 7, immagine 2 di 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Heat Sink Replacement: passo 8, immagine 1 di 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Heat Sink Replacement: passo 9, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 9, immagine 2 di 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Heat Sink Replacement: passo 10, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 10, immagine 2 di 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Heat Sink Replacement: passo 11, immagine 1 di 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Heat Sink Replacement, Hard Drive: passo 12, immagine 1 di 3 Xbox 360 S Heat Sink Replacement, Hard Drive: passo 12, immagine 2 di 3 Xbox 360 S Heat Sink Replacement, Hard Drive: passo 12, immagine 3 di 3
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  13. Xbox 360 S Heat Sink Replacement: passo 13, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 13, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 13, immagine 3 di 3
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
    yamboboy - Replica
    You will still have your saves and account if you replace your hard drive in the new xbox
    Robert Miller -
    hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
    Cesar Tourreilles - Replica
    My fabric was accidentally ripped off years ago. What do I do?
    org 2026 - Replica
    Stick another bit on there
    Josh Cool -
  14. Xbox 360 S Heat Sink Replacement, Bottom Panel: passo 14, immagine 1 di 1
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  15. Xbox 360 S Heat Sink Replacement: passo 15, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 15, immagine 2 di 2
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  16. Xbox 360 S Heat Sink Replacement: passo 16, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 16, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 16, immagine 3 di 3
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  17. Xbox 360 S Heat Sink Replacement: passo 17, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 17, immagine 2 di 2
    • Remove the bottom vent by lifting it away from the bottom bezel.
  18. Xbox 360 S Heat Sink Replacement: passo 18, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 18, immagine 2 di 2
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  19. Xbox 360 S Heat Sink Replacement: passo 19, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 19, immagine 2 di 2
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
    These are pretty awkward to remove, but once you understand how they work its easy enough. The goal here is to slot the spudger THROUGH the gap of the silver tabs (visible in previous steps image, circled) and then pry. Put pressure against the wall of the Xbox case and push downwards, once you feel the spudger slot in, then apply force away from the Xbox and pull up a little with your free hand.
    Spaced Invader - Replica
  20. Xbox 360 S Heat Sink Replacement: passo 20, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 20, immagine 2 di 2
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  21. Xbox 360 S Heat Sink Replacement: passo 21, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 21, immagine 2 di 2
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  22. Xbox 360 S Heat Sink Replacement: passo 22, immagine 1 di 1
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  23. Xbox 360 S Heat Sink Replacement: passo 23, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 23, immagine 2 di 2
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  24. Xbox 360 S Heat Sink Replacement, Left Case: passo 24, immagine 1 di 1
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
    Does not void the warranty in the United States according to the FTC that sent a cease and desist letter directly to Microsoft about this exact issue.
    Jeff - Replica
  25. Xbox 360 S Heat Sink Replacement: passo 25, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 25, immagine 2 di 2
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
    Retiring the WiFi module, this task gets a lot easier
    Luismi Carmona - Replica
  26. Xbox 360 S Heat Sink Replacement: passo 26, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 26, immagine 2 di 2
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Heat Sink Replacement: passo 27, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 27, immagine 2 di 2
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Heat Sink Replacement: passo 28, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 28, immagine 2 di 2
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Heat Sink Replacement: passo 29, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 29, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 29, immagine 3 di 3
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
    if you make a hole right here like the link`s picture you can boot the lock
    https://scontent-mia.xx.fbcdn.net/hphoto...
    Midguet Garcia - Replica
    As the user above me said, please avoid doing it like shown in the guide. It just didn’t work on my Xbox (unless your goal is to destroy the plastic case). Instead, pick some small needle like object (the spudger was too short for this, I used the SIM bit of my iFixit driver kit) and find the right spot on the big sticker which is on the left in the pictures shown in the guide. That spot is just between the text and the column of logos (Dolby Digital, etc.) (https://team-xecuter.com/slim/slim_secre..., picture not mine). Poke it (don’t be too gentle, you have to apply some force) and you will hear the clip release.
    Davide Volta - Replica
    Both the above links are dead, i used this YouTube video which shows you the process of getting the hidden clip
    https://youtu.be/dFD94d6mDFE
    Kenny Montgomery - Replica
    I was able to open it by pushing on the sticker to unclamp the clip while another person helped me pull open the case.
    StellularWolf51 - Replica
    Here is a Video that shows the small hole behind the sticker, ist in german but ist good to see how to open that hidden clip easiely.
    https://www.youtube.com/watch?v=Bsy5IUVg...
    Michael Buß - Replica
  30. Xbox 360 S Heat Sink Replacement: passo 30, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 30, immagine 2 di 2
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
  31. Xbox 360 S Heat Sink Replacement: passo 31, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 31, immagine 2 di 2
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
  32. Xbox 360 S Heat Sink Replacement, Faceplate: passo 32, immagine 1 di 2 Xbox 360 S Heat Sink Replacement, Faceplate: passo 32, immagine 2 di 2
    • Orient the console right-side-up, with the faceplate facing forward.
    • Release the clip near the front right corner of the top edge securing the right case to the faceplate.
    There are 4 black screw that has to be removed before you can detach the other cover. Please note
    emmoski4real - Replica
    Sorry, there 5screws, one in the middle and 4 at the edges
  33. Xbox 360 S Heat Sink Replacement: passo 33, immagine 1 di 1
    • Turn the console over, so that the bottom is facing upward, and the faceplate is facing forward.
    • Release the clip in the bottom right corner of the top edge securing the right case to the front case.
  34. Xbox 360 S Heat Sink Replacement: passo 34, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 34, immagine 2 di 2
    • Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
    • Detach the faceplate from the rest of the device.
    • The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
    It is easier to perform step 40 before 34 (unscrew the long torx screws to make the right case flexible)
    Peter - Replica
    There isn’t 2 clips there is 4 clips
    Daniel Mattes - Replica
  35. Xbox 360 S Heat Sink Replacement: passo 35, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 35, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 35, immagine 3 di 3
    • Using a spudger or fingernail, lift the clear blue tab away from the connector.
    • Slide the locking tab on the power switch board cable connector toward the top of the console.
    • The locking tab will only move about 2 mm.
    • Pull the power switch cable straight out of the connector.
    • The faceplate is now free of the rest of the console.
  36. Xbox 360 S Heat Sink Replacement, RF Module: passo 36, immagine 1 di 1
    • Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
    On my disassembly during this part, I found the T9 Torx to be too big and had to use the T8 Torx instead.
    weitmeyerj - Replica
    The correct size is T8!
    thomasforster - Replica
    I guess you need to check for your own size : I used the TR9 as the TR8 was a little too loose.
    sirmyself - Replica
  37. Xbox 360 S Heat Sink Replacement: passo 37, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 37, immagine 2 di 2
    • The RF module is still connected to the Xbox by a large USB-type connector.
    • Pull the board directly away from the Xbox to remove it.
    This step is not needed.
    Wade - Replica
    It may not be required but recommended. As you move the xbox around you could break this part. Removing it and placing it in a safe place keeps that from happening.
    junkyardjojo - Replica
    Is the rf module married to the mother board? Im trying to replace the piece but dont want to start if it is not compatible.
    jake - Replica
  38. Xbox 360 S Heat Sink Replacement, Wi-Fi Board: passo 38, immagine 1 di 3 Xbox 360 S Heat Sink Replacement, Wi-Fi Board: passo 38, immagine 2 di 3 Xbox 360 S Heat Sink Replacement, Wi-Fi Board: passo 38, immagine 3 di 3
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi Board out of the console.
  39. Xbox 360 S Heat Sink Replacement, Right Case: passo 39, immagine 1 di 1
    • This is the terminal point if you ever want to send your Xbox back to Microsoft for repair.
    • Remove the large white warranty sticker from the metal frame to expose a screw.
  40. Xbox 360 S Heat Sink Replacement: passo 40, immagine 1 di 1
    • Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
  41. Xbox 360 S Heat Sink Replacement: passo 41, immagine 1 di 1
    • Turn the Xbox over so the right case is facing up.
    • Lift the right case off by its metal framework.
  42. Xbox 360 S Heat Sink Replacement, Optical Drive: passo 42, immagine 1 di 2 Xbox 360 S Heat Sink Replacement, Optical Drive: passo 42, immagine 2 di 2
    • Disconnect the optical drive data cable from the back of the optical drive.
    • Disconnect the power cable from the back of the optical drive.
  43. Xbox 360 S Heat Sink Replacement: passo 43, immagine 1 di 1
    • Lift the optical drive out of the Xbox.
    Is there a specific Optical Drive that Microsoft uses in these or can I upgrade my drive?
    whitemare0 - Replica
    i took my drive out but when installed my replacement it would not work
    davidgardner301 - Replica
    WAS thinking of possibly trying to repair my son's Xbox 360S, by replacing the optical drive, but after looking at all the spudger steps to get to the drive and then your comment that the replacement might not actually work... forget about it! I ain't going to all that work for possibly nothing... t'ain't worth it!
    Anyone want a perfectly working Xbox 360S with a drive the spins game discs upon ejection? We've already bought a replacement, so this unit is for sale... name your price.
    Luposian -
    In regards to davidgardner301 comment there is a extra step they. Didn't show on this replacement guide in order for your new disk drive to work you will need to remove the origional board connected to thje origional drive that came with the system and soler that onto the new one its a tricky process however its a step most people over look
    Without the origional board the xbox will not accept the replacement drive only because each disk drive is coded to work with tat soecific xbox only so your out of luck if you already. Tossed out your old disk drive
    Eric Liu - Replica
    So I installed the drive but the thing keeps reading the games as dvds, hence; wont play them, why?
    BigD29853 - Replica
    The DVD drives are coded to the Motherboard. If you buy the same exact drive to replace the broken one. You will still need to either 1) transfer the DVD circuit board OR 2) get the Firmware from the old DVD drive using a PC and then transfer it to the New DVD. There are website regarding this procedure if you want to look it up.
    Lawrence - Replica
  44. Xbox 360 S Heat Sink Replacement, Hard Drive Bracket: passo 44, immagine 1 di 1
    • Turn the console over so that the metal case is facing up.
    • Remove the single 11.3 mm gold T10 Torx screw from the hole marked "G."
    Could be preferable to do this step along with step #47 since the screws fasten the same plastic part.
    sirmyself - Replica
  45. Xbox 360 S Heat Sink Replacement: passo 45, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 45, immagine 2 di 2
    • Lift the fan duct off the fan.
    • There is a locator peg underneath the fan duct (top right corner of the fan duct as viewed in the pictures). When reinstalling look down the screw hole to aid alignment.
  46. Xbox 360 S Heat Sink Replacement: passo 46, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 46, immagine 2 di 2
    • Remove the single 9.2 mm T10 Torx screw securing the hard drive cable connector to the plastic bracket.
    • Lift the hard drive cable connector off the hard drive bracket.
  47. Xbox 360 S Heat Sink Replacement: passo 47, immagine 1 di 1
    • Remove the 11.3 mm T10 Torx screw holding the hard drive bracket to the metal frame, near the DC-In port.
  48. Xbox 360 S Heat Sink Replacement: passo 48, immagine 1 di 1
    • Lift the hard drive bracket out of the metal frame.
    I have a 4GB Xbox 360 slim and I bought a 500GB hard drive for it. I pushed the hard drive in its place and after I heard that click, I pushed it a little bit more to be shure that it's in place. I noticed that the hard drive bracket (the slide that holds the hard drive) it's elastic: after the hard drive is inserted, it wobbles (maybe to prevent hdd damage when the xbox is moved).
    My question is: how does the hard drive bracket work? is there a metal spring in its mechanism that allows it to wobble? Did I make any damage to it because I pushed the hard drive to be sure that it is in place? I don't want to teardwon my console to find that out.
    Thank you!
    atitus87 - Replica
  49. Xbox 360 S Heat Sink Replacement, Fan: passo 49, immagine 1 di 1
    • Disconnect the fan cable by pulling its connector off the logic board.
    What is the size and name if the connector in the fan?
    Fernando Salazar - Replica
  50. Xbox 360 S Heat Sink Replacement: passo 50, immagine 1 di 3 Xbox 360 S Heat Sink Replacement: passo 50, immagine 2 di 3 Xbox 360 S Heat Sink Replacement: passo 50, immagine 3 di 3
    • Unscrew the two 11.7 mm Phillips screws securing the fan to the heat sink in the bottom right and top left corners of the fan.
    • Remove the fan from the logic board assembly.
  51. Xbox 360 S Heat Sink Replacement, Motherboard: passo 51, immagine 1 di 1
    • There are a total of 10 screws holding the logic board assembly to the metal case:
    • Five 11.3 mm silver T10 Torx screws, in the holes marked "M", "N", "P", "R", and "T".
    • Four 5.6 mm black T9 Torx screws in the holes marked "D", "E", "J", and "K".
    • A single 11.3 mm gold T10 Torx screw in the hole marked "A".
    Correct size for the orange screws is T8!
    I confirm what the user above me said, they were T8, at least on my Xbox.
    T8 works for me as well
    Nicholas - Replica
    I don't have the gold one. Is it normal?
    aklardon amarcanda - Replica
    My gold and silver screws were reversed. 5 gold, 1 silver.
    Jared Boehm - Replica
  52. Xbox 360 S Heat Sink Replacement: passo 52, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 52, immagine 2 di 2
    • Lift the optical drive retaining bracket off the logic board.
  53. Xbox 360 S Heat Sink Replacement: passo 53, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 53, immagine 2 di 2
    • Grab the heat sink with one hand, and hold the metal frame with the other.
    • Lift the logic board assembly out of the metal frame.
    • Removing the logic board assembly will require some force.
  54. Xbox 360 S Heat Sink Replacement, Heat Sink: passo 54, immagine 1 di 2 Xbox 360 S Heat Sink Replacement, Heat Sink: passo 54, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Turn the logic board assembly over to access the heat sink's x-clamp.
    • To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
    • The logic board is very sensitive to impact and scratching. Be sure to not let the screwdriver slip and damage the logic board.
    • Starting at the front left corner of the x-clamp, insert a 1.5 mm flathead screwdriver between the heat sink's peg and the x-clamp's hook.
    • If you're worried about scratching the logic board, insert a spudger or thin screwdriver down through one of the holes in the x-clamp, in the gap just inside the screw post. Pry outward to release the x-clamp. Repeat for the opposite arm.
    Uggghhhh, Microsoft is still using X-Clamps. Didn't they learn anything from the original 360?
    Chris Green - Replica
    Hopefully having the smaller CPU and GPU on the same die, as well as an "improved fan cooling system" will keep those old issues from rearing their ugly heads. The Red Ring of Death technically doesn't exist anymore, either.
    David Hodson -
    I've been reading that people are ruining their boards on this step when they slip and the tool slices the main board while trying to remove the x-clamp. Use a metal spudger and slip it between the post and the x-clamp from ABOVE... not along the bottom where the board is. The whole clamp came off in 30 seconds and the spudger was nowhere near the pcb.
    tfreeman075 - Replica
  55. Xbox 360 S Heat Sink Replacement: passo 55, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 55, immagine 2 di 2
    • Rotate the logic board 90 degrees clockwise.
    • In the same manner described above, release the rear right hook of the x-clamp.
  56. Xbox 360 S Heat Sink Replacement: passo 56, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 56, immagine 2 di 2
    • Rotate the logic board 180 degrees counter-clockwise.
    • In the same manner described above, release the rear left hook of the x-clamp.
  57. Xbox 360 S Heat Sink Replacement: passo 57, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 57, immagine 2 di 2
    • Lift the x-clamp off the back of the logic board.
  58. Xbox 360 S Heat Sink Replacement: passo 58, immagine 1 di 2 Xbox 360 S Heat Sink Replacement: passo 58, immagine 2 di 2
    • Using one hand to hold the heat sink in place, carefully turn the logic board over.
    • Lift the heat sink off of the logic board.
    • Before reinstallation, follow our thermal paste guide to replace the thermal compound between the heat sink and processor.
Conclusione
Altre 68 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.503 Reputazione
127 Guide realizzate
16 Commenti
This is a great guide. Thank you for taking the time to make it.
Brian Douglas - Replica
Intercooler guys, purchase an intercooler and save yourself from this hassle
haywirestudent7 - Replica
I had problems getting the x-bracket off the back (step 54-57).
I found this video using a pair of needle nose pliers that helped me immensely with this step:
https://www.youtube.com/watch?v=dDAW_tRi...
Matt Bailey - Replica
I think we all ended up finding that video...
rasskipper -
Thank you for taking the time to make this very instructional guide
Michael Wiley - Replica
I bought the single kit with tools and the multi fix kit. The kits come with mini heat sinks, pads, washers and screws. Nothing in this set of directions tells me where to use them.? Are there other directions somewhere that I have as yet not found?
David Hoppe - Replica
This is an awesome guide that I only found after getting stuck trying to remove the heat sink - wish I had found it before I started. Once removed I found an odd pattern of thermal paste, the circle of copper on the heat sink and beneath it on the chip only had a few spattering’s of thermal paste - is it possible that heat pushed the thermal paste out to the boundaries of the chip?
I’m going to go look for a recommendation of what type of thermal paste I should put back down.
Glenn Compton - Replica
Why didn’t u show us how to reinstall the X clamp bracket. Its not as easy as just sticking it on so maybe don’t forget that.
The Realist - Replica
Hey guys I figured out how to put the bracket back on with out killing the mobo. Here follow this:
So first off u need to look back at the part where u take off the bracket. That way u know what way the bracket came off as. This might not matter but I couldn’t get mine with out lining it up correctly from when I removed it so do that first.
Then put new thermal paste on the CPU>put heatsink threw mobo and flip the mobo over.
Now align the bracket as u did before u took it off, then hook the bracket on one end of the heatsink screw holes. Now push firmly down on the opposite screw hole from the one u are notched on right now. If u do it right u should have those 2 brackets parts notched on the screw holes. If not take off the brackets and try again. Once done with the first set simply do the same thing to the last set.
Hope this helps for those like me who got confused when there wasn’t a section showing how to put the bracket back on.
Is the Heatsink on this model your showing have the old, original, upgraded or newest one? My daughter's Slim was very dirty dusty & clogged cooling intake and I cleaned it. She has an external fan also that plug into USB port and it is obvious why overheating but I want to know if heatsink should be replaced it has that same circle copper center core heatsink. I have looked at a couple of heatsink sites online showing progression of changing of sinks xbox went through but not this one. I'm hoping it is the newer or better yet the newest style. I have artic silver 5 thermal paste I use on video cards & processors on my computer builds & repairs. I don't know what paste the xbox360 slim uses and I have seen the crappy thermal pads used in some Compaq Laptops for the video processor which I switch out for a copper plate thermal pasted and the heat immediately goes away. If you know which sink this is should I switch it or just take it off and replace the paste? Thanks
James Hamicksburg
יעקב המיקסברג
J. Hamicksburg - Replica
I starred this guide because I like long guides, as well as well-organized ones. Yours is both! You’re welcome!
Michael Deitz - Replica
It is great! Do you any of you guys have any information what is the space (its like a cpu socket on pc’s) between the cpu holding holes. I’m asking because i’d like to put on a aio watercooilng kit into it. :) Thanks.
Peter Kvcs Tlk - Replica
What is that metal embedded in the heatsink? Is it copper?
geraldcherney - Replica
two scratches because of how hard the heatsink is hard to take off and one stab to the mobo because of how hard it was to screw the fan back, and the thing still works. 10/10 would accidentally damage my xbox again
Idris Anwar - Replica
haywirestudent7 - that is like putting a band-aid on something. It might work but it isn’t proper or recommended whatsoever. TIM doesn’t last forever. Replacing something defective is highly more advisable then doing something unnecessary.
taylor craig - Replica
It is easier to remove the X bracket by using a small flathead screwdriver or spudger to pry between a post and the inside edge of the opening (the side nearest the center). This will disengage the hook on the opposite side of the X. Releasing two ends that are side-by-side allows for removal by only working on two legs.
When separating the second part of the main case, there is no need to damage the edges of the plastic. There really is a small (about 1mm) hole near the "checkmark" under the tough plastic sticker. You still need to remove the little Warranty Sticker, because that binds the two pieces of the case. Pushing very firmly on the black sticker with the pad of your thumb will make a faint dimple where the hole is; puncture it with something sharp, then press a straightened paper clip through the hole to release the clip.
LordRegent - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 21
Ultimi 7 Giorni: 165
Ultimi 30 Giorni: 497
Tutti i Tempi: 88,569
