Salta al contenuto principale
Withings Smart Body Analyzer Pressure Sensor Replacement
Cosa ti serve
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: passo 1, immagine 1 di 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Chiedi a FixBot
      Aggiungi Commento
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: passo 2, immagine 1 di 3 Withings Smart Body Analyzer Pressure Sensor Replacement: passo 2, immagine 2 di 3 Withings Smart Body Analyzer Pressure Sensor Replacement: passo 2, immagine 3 di 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Chiedi a FixBot
      Aggiungi Commento
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: passo 3, immagine 1 di 2 Withings Smart Body Analyzer Pressure Sensor Replacement: passo 3, immagine 2 di 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Chiedi a FixBot
      Aggiungi Commento
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: passo 4, immagine 1 di 1
      • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
      • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
      Chiedi a FixBot
      Aggiungi Commento
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: passo 5, immagine 1 di 2 Withings Smart Body Analyzer Pressure Sensor Replacement: passo 5, immagine 2 di 2
      • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
      Chiedi a FixBot
      Aggiungi Commento
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: passo 6, immagine 1 di 2 Withings Smart Body Analyzer Pressure Sensor Replacement: passo 6, immagine 2 di 2
      • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
3Commenti sulla guida
Where do I get those replacements?
karina - Rispondi Condividi
where can I buy pressure sensors?
Andrey Kolesov - Rispondi Condividi
The issue is not the pressure sensor, but a weak area within the foot.
Having taken my scales apart to repair them I found the the foot (pictured within the plastic ring above) has a metal disc in it, that is supported by a few weak plastic ribs that easily damage. I filled them in with Araldyte to create a firm level surface and all is good again.
As a design engineer who fault-finds all day, I would say this is either poor design (an oversight), or brilliant salesmanship (a weak point that allows Withings to sell more scales). Which is true? Only they know.
FlashingIcon - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 50
Tutti i Tempi: 4,786
