Salta al contenuto principale
Wiko View Screen Replacement
Cosa ti serve
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    • Ground yourself the best you can to avoid damaging any little component.
    • If you have one, you can use the iFixit Anti-Static Wrist Strap.
  1. Wiko View Screen Replacement, Remove the back cover: passo 2, immagine 1 di 2 Wiko View Screen Replacement, Remove the back cover: passo 2, immagine 2 di 2
    • Locate the small gap in the bottom-right corner to separate the back cover from the phone's frame.
    • Pull slowly until you can lift the corner enough to grab the back cover with your fingers. You can use an opening pick for help.
    • Pull the back cover along all the sides to completely separate from the rest of the phone.
    • The back cover can tolerate a little bending but don't bend too much otherwise it will crack.
  2. Wiko View Screen Replacement, Remove the battery: passo 3, immagine 1 di 3 Wiko View Screen Replacement, Remove the battery: passo 3, immagine 2 di 3 Wiko View Screen Replacement, Remove the battery: passo 3, immagine 3 di 3
    • Once the back cover is completely removed, you can remove the battery by lifting it from the bottom-left corner.
    • There is another small gap for help.
    • You won't need the help of any tool for this.
    • From now on, be very careful not to damage the tiny metal springs. The next steps will remove any protection for them; they are thin and very easy to break.
    • If you break one of them, you need to do precision soldering (or just tape it back in place with electrical tape for a quicker but very cheap solution).
  3. Wiko View Screen Replacement, Remove the top plastic cover: passo 4, immagine 1 di 3 Wiko View Screen Replacement, Remove the top plastic cover: passo 4, immagine 2 di 3 Wiko View Screen Replacement, Remove the top plastic cover: passo 4, immagine 3 di 3
    • Remove every SIM or SD card from the slots.
    • Unscrew all the six screws from the top plastic cover.
    • Start to lift gently the cover using opening picks from its bottom-right corner.
    • Only insert the pick up to 3.5 mm to avoid damaging the internals.
    • Keep pushing the opening pick along all the external sides of the plastic cover.
    • You need to open all the plastic clips hidden under the cover itself. You can notice a soft "pop" when opening successfully one of them.
    • When all the clips are opened, you can lift the cover completely with caution.
  4. Wiko View Screen Replacement, Unplug power buttons: passo 5, immagine 1 di 1
  5. Wiko View Screen Replacement, Unplug display and bottom circuit: passo 6, immagine 1 di 1
    • Unplug the display-touch digitizer and bottom circuit connectors with the help of a spudger.
    • They are both press connectors.
  6. Wiko View Screen Replacement, Remove the bottom plastic cover: passo 7, immagine 1 di 3 Wiko View Screen Replacement, Remove the bottom plastic cover: passo 7, immagine 2 di 3 Wiko View Screen Replacement, Remove the bottom plastic cover: passo 7, immagine 3 di 3
    • Unscrew all four screws.
    • Like in the Step 4, use an opening pick to lift and remove carefully the cover from the bottom-left corner.
    • We are not going to remove the bottom motherboard in this guide.
  7. Wiko View Screen Replacement, Remove the motherboard: passo 8, immagine 1 di 3 Wiko View Screen Replacement, Remove the motherboard: passo 8, immagine 2 di 3 Wiko View Screen Replacement, Remove the motherboard: passo 8, immagine 3 di 3
    • Unscrew the two screws that hold the motherboard.
    • Do not apply force to remove the motherboard, otherwise you will cut the antenna cable.
    • Gently lift the motherboard passing the cable under the plastic frame and go to the next step.
  8. Wiko View Screen Replacement, Remove the antenna cable: passo 9, immagine 1 di 2 Wiko View Screen Replacement, Remove the antenna cable: passo 9, immagine 2 di 2
    • Unplug the antenna cable from both ends.
    • It has a coaxial connector.
    • Remember to reconnect the antenna cable before remounting the motherboard.
  9. Wiko View Screen Replacement, Remove the sticker: passo 10, immagine 1 di 2 Wiko View Screen Replacement, Remove the sticker: passo 10, immagine 2 di 2
    • With the help of a tweezer, remove slowly the back sticker.
    • Take note of the codes written in case it breaks.
    • After the substitution, you can put it back where was.
  10. Wiko View Screen Replacement, Unplug the motherboard's link cable: passo 11, immagine 1 di 2 Wiko View Screen Replacement, Unplug the motherboard's link cable: passo 11, immagine 2 di 2
    • Unplug the cable that links the two motherboards.
    • Do not completely remove the cable from the metal case.
  11. Wiko View Screen Replacement, Remove the display cable: passo 12, immagine 1 di 3 Wiko View Screen Replacement, Remove the display cable: passo 12, immagine 2 di 3 Wiko View Screen Replacement, Remove the display cable: passo 12, immagine 3 di 3
    • First, unplug the cable from the bottom motherboard.
    • It's a "no-fuss" ribble cable connector.
    • Then slowly pull the bigger cable.
    • The cable is glued to the metal case.
    • Be sure to lift the cable for all its length, so the adhesive won't keep it in place and break it in the following steps.
    • Do not completely remove the cable - it is linked to the display under the metal case.
    • Remove the grey adhesive.
  12. Wiko View Screen Replacement, Remove the display: passo 13, immagine 1 di 3 Wiko View Screen Replacement, Remove the display: passo 13, immagine 2 di 3 Wiko View Screen Replacement, Remove the display: passo 13, immagine 3 di 3
    • Heat an iOpener and apply it to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone - the display is susceptible to heat damage.
    • Apply a suction cup to the screen, as close to the center of the right edge as possible, and pull up with strong, steady force to create a gap between the bezel and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again. You can also use a Jimmy instead (being very careful not to scratch the metal frame). If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Release all the clips and unglue the screen.
    • Pull the cable through the frame's opening.
  13. Wiko View Screen Replacement, Remove adhesives: passo 14, immagine 1 di 1
    • Remove the adhesive backings from the new part
    • Remove the protective adhesive in front of the screen only when the reparation is complete.
  14. Wiko View Screen Replacement, Transfer the remaining components: passo 15, immagine 1 di 3 Wiko View Screen Replacement, Transfer the remaining components: passo 15, immagine 2 di 3 Wiko View Screen Replacement, Transfer the remaining components: passo 15, immagine 3 di 3
    • Compare your new replacement part to the original part - you may need to transfer the remaining components.
    • For example:
    • The ear capsule grid.
    • The lens of the internal flash.
  15. Wiko View Screen Replacement, Add the new adhesive: passo 16, immagine 1 di 3 Wiko View Screen Replacement, Add the new adhesive: passo 16, immagine 2 di 3 Wiko View Screen Replacement, Add the new adhesive: passo 16, immagine 3 di 3
    • Fill all the screen's borders with the double-sided adhesive.
    • You can use the precision tweezer and spudger to help you position and compress the tape in place.
  16. Wiko View Screen Replacement, Place the new display cable: passo 17, immagine 1 di 2 Wiko View Screen Replacement, Place the new display cable: passo 17, immagine 2 di 2
    • Insert the new display cable in the metal case opening.
  17. Wiko View Screen Replacement, Install the new display: passo 18, immagine 1 di 1
    • Remove all the protective layers from the placed tape.
    • Push the display into the frame.
    • Let the glue dry.
  18. Wiko View Screen Replacement, Place the new display cable: passo 19, immagine 1 di 3 Wiko View Screen Replacement, Place the new display cable: passo 19, immagine 2 di 3 Wiko View Screen Replacement, Place the new display cable: passo 19, immagine 3 di 3
    • Remove the protective layer from the main cable's adhesive.
    • Place the main cable parallel to the orange one.
Conclusione
You can take the opportunity to clean in-depth your device.
Before completely closing your device, make some tests for the display and touch.
Leave your device under a book or some soft weight for a couple of hours to let the screen adhesive stick well.
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 143
