Salta al contenuto principale
Whirlpool Refrigerator Start Relay Assembly Replacement
Cosa ti serve
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: passo 3, immagine 3 di 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: passo 4, immagine 3 di 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: passo 5, immagine 3 di 3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: passo 6, immagine 3 di 3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, immagine 1 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, immagine 2 di 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: passo 7, immagine 3 di 3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 5 persone hanno completato questa guida.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
2Commenti sulla guida
Is it universal part
dyannatorres@yahoo.com - Replica
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 323
Tutti i Tempi: 14,105
