Salta al contenuto principale
Vtech InnoTab 3S Camera Replacement
Cosa ti serve
  1. Vtech InnoTab 3S Camera Replacement, Rear Panel: passo 1, immagine 1 di 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: passo 1, immagine 2 di 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: passo 1, immagine 3 di 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Vtech InnoTab 3S Camera Replacement: passo 2, immagine 1 di 2 Vtech InnoTab 3S Camera Replacement: passo 2, immagine 2 di 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Vtech InnoTab 3S Camera Replacement: passo 3, immagine 1 di 3 Vtech InnoTab 3S Camera Replacement: passo 3, immagine 2 di 3 Vtech InnoTab 3S Camera Replacement: passo 3, immagine 3 di 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
    Chiedi a FixBot
    Aggiungi Commento
  4. Vtech InnoTab 3S Camera Replacement: passo 4, immagine 1 di 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
    Chiedi a FixBot
    Aggiungi Commento
  5. Vtech InnoTab 3S Camera Replacement, Camera: passo 5, immagine 1 di 2 Vtech InnoTab 3S Camera Replacement, Camera: passo 5, immagine 2 di 2
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection between the motherboard and the camera is located at the near the top of the device.
    • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
    • Carefully lower the latch until you hear a click to secure the new camera to the device.
    • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 8-2, Eyestone Fall 2015 Membro di USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Membri
9 guide realizzate
4Commenti sulla guida
Where do you get the replacement camera? I can't find them online.
rongennero - Rispondi Condividi
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - Rispondi Condividi
Where can i buy the camera?
Stephan Meyer - Rispondi Condividi
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 30
Tutti i Tempi: 2,352
