Salta al contenuto principale
Volkswagen Key Fob Battery Replacement
Cosa ti serve
    1. Volkswagen Key Fob Battery Replacement, Identification: passo 1, immagine 1 di 1
      • There are two main key fob models when it comes to repair.
      • If you see this shiny pin it means it’s the easiest of the two.
      • If this is not the case, the other iFixit guides on Volkswagen key fobs deal with the other replacement method.
      Chiedi a FixBot
      Aggiungi Commento
    2. Volkswagen Key Fob Battery Replacement, Opening: passo 2, immagine 1 di 1
      • Pull from the small plastic square in the direction of the arrow to release the casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Volkswagen Key Fob Battery Replacement, Swap the battery: passo 3, immagine 1 di 2 Volkswagen Key Fob Battery Replacement, Swap the battery: passo 3, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      Spudger
      $3.99
      • Insert a spudger or a pointed object inside of the marked ledge to help release the battery.
      • Replace the battery and congrats!! You are done.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
carlotremolada
Membro da: 08/15/23
2.947 Reputazione
Una guida realizzata
German Translators Membro di German Translators
Community
51 Membri
5.545 guide realizzate
3Commenti sulla guida
very helpful!
drai - Rispondi Condividi
It's easy, but I was afraid of doing damage and was about to go to a Volkswagen centre. Very useful guide
Kodama - Rispondi Condividi
The key generally is too sensitive mine just stopped working and it was not the battery and I had to open the car manually . I lost the spare key and a new one took 2 months to order and cost about 250 dollars ! Yes you read that right !
Stephen J Whitworth - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 14
Ultimi 7 giorni: 65
Ultimi 30 giorni: 232
Tutti i Tempi: 8,203
