Salta al contenuto principale
Vivitar DVR 781HD Screen Replacement
Cosa ti serve
  1. Vivitar DVR 781HD Screen Replacement, Front Case: passo 1, immagine 1 di 3 Vivitar DVR 781HD Screen Replacement, Front Case: passo 1, immagine 2 di 3 Vivitar DVR 781HD Screen Replacement, Front Case: passo 1, immagine 3 di 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
    Chiedi a FixBot
    Aggiungi Commento
  2. Vivitar DVR 781HD Screen Replacement: passo 2, immagine 1 di 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
    Chiedi a FixBot
    Aggiungi Commento
  3. Vivitar DVR 781HD Screen Replacement: passo 3, immagine 1 di 3 Vivitar DVR 781HD Screen Replacement: passo 3, immagine 2 di 3 Vivitar DVR 781HD Screen Replacement: passo 3, immagine 3 di 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
    Chiedi a FixBot
    Aggiungi Commento
  4. Vivitar DVR 781HD Screen Replacement, Motherboard: passo 4, immagine 1 di 2 Vivitar DVR 781HD Screen Replacement, Motherboard: passo 4, immagine 2 di 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
    Chiedi a FixBot
    Aggiungi Commento
  5. Vivitar DVR 781HD Screen Replacement: passo 5, immagine 1 di 1
    • Gently lift the motherboard, handling it by the edges.
    Chiedi a FixBot
    Aggiungi Commento
  6. Vivitar DVR 781HD Screen Replacement, Screen: passo 6, immagine 1 di 2 Vivitar DVR 781HD Screen Replacement, Screen: passo 6, immagine 2 di 2
    • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Vivitar DVR 781HD Screen Replacement: passo 7, immagine 1 di 2 Vivitar DVR 781HD Screen Replacement: passo 7, immagine 2 di 2
    • Turn the motherboard and screen over.
    • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
    Chiedi a FixBot
    Aggiungi Commento
  8. Vivitar DVR 781HD Screen Replacement: passo 8, immagine 1 di 1
    • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 54-6, Wilson Spring 2016 Membro di IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Membri
13 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 11
Ultimi 30 giorni: 38
Tutti i Tempi: 952
