Salta al contenuto principale
Verizon Wireless CDM 7075 Keypad Replacement
Cosa ti serve
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: passo 1, immagine 1 di 2 Verizon Wireless CDM 7075 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Verizon Wireless CDM 7075 Keypad Replacement: passo 2, immagine 1 di 1
    • Carefully remove the battery from the phone by prying the battery from the top.
    Chiedi a FixBot
    Aggiungi Commento
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: passo 3, immagine 1 di 1
    • Pry off the top cover on the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. Verizon Wireless CDM 7075 Keypad Replacement: passo 4, immagine 1 di 1
    • You will then remove the screws from the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. Verizon Wireless CDM 7075 Keypad Replacement: passo 5, immagine 1 di 1
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
    Chiedi a FixBot
    Aggiungi Commento
  6. Verizon Wireless CDM 7075 Keypad Replacement: passo 6, immagine 1 di 1
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. Verizon Wireless CDM 7075 Keypad Replacement: passo 7, immagine 1 di 1
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device follow these instructions in reverse order.
Corey Ryman
Membro da: 10/14/11
255 Reputazione
4 guide realizzate
James Madison, Team 2-4, Allen Fall 2011 Membro di James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 1,495
