Salta al contenuto principale
Verizon Ellipsis 8 Disassembly
Cosa ti serve
    1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: passo 1, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
      Chiedi a FixBot
      Aggiungi Commento
    2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: passo 2, immagine 1 di 1
      • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
      • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
      Chiedi a FixBot
      Aggiungi Commento
    3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: passo 3, immagine 1 di 2 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: passo 3, immagine 2 di 2
      • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
      • You can look at the picture of the rear cover to see where the snaps are located.
      Chiedi a FixBot
      Aggiungi Commento
    4. Verizon Ellipsis 8 Disassembly, Remove Battery: passo 4, immagine 1 di 1
      • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
      • There was no adhesive on the back of the battery, just along the sides.
      Chiedi a FixBot
      Aggiungi Commento
    5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, immagine 1 di 3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, immagine 2 di 3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: passo 5, immagine 3 di 3
      • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
      • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
      • **Be careful with the antenna cable!**
      Chiedi a FixBot
      Aggiungi Commento
    6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: passo 6, immagine 1 di 1
      • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
      • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 31 persone hanno completato questa guida.
SMcC21985
Membro da: 11/10/15
1.271 Reputazione
2 guide realizzate
4Commenti sulla guida
what size screws are thoze i need to get some i lost some
stacy - Rispondi Condividi
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - Rispondi Condividi
My tablet is on working, when I press to get is frozen, it doesn't let me in
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 65
Tutti i Tempi: 21,350
