Salta al contenuto principale
VTech Write and Learn Creative Center Slider Replacement
Cosa ti serve
  1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 1 di 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 2 di 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
    Chiedi a FixBot
    Aggiungi Commento
  2. VTech Write and Learn Creative Center Slider Replacement, Slider: passo 2, immagine 1 di 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 36
Tutti i Tempi: 748
