Salta al contenuto principale
VTech Write and Learn Creative Center Magnetic Screen Replacement
Cosa ti serve
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 1 di 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 2 di 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 3 di 3
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: passo 2, immagine 1 di 1
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, immagine 1 di 2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, immagine 2 di 2
      • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech Write and Learn Creative Center Magnetic Screen Replacement: passo 4, immagine 1 di 1
      • Gently push the edges of the screen to remove it from the front case.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
2Commenti sulla guida
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - Rispondi Condividi
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 30
Tutti i Tempi: 1,887
