Salta al contenuto principale
VTech InnoTab Max Camera Replacement
Cosa ti serve
    1. VTech InnoTab Max Camera Replacement, Cover: passo 1, immagine 1 di 3 VTech InnoTab Max Camera Replacement, Cover: passo 1, immagine 2 di 3 VTech InnoTab Max Camera Replacement, Cover: passo 1, immagine 3 di 3
      • Remove all screw caps from the back panel using a metal spudger.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech InnoTab Max Camera Replacement: passo 2, immagine 1 di 3 VTech InnoTab Max Camera Replacement: passo 2, immagine 2 di 3 VTech InnoTab Max Camera Replacement: passo 2, immagine 3 di 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    3. VTech InnoTab Max Camera Replacement: passo 3, immagine 1 di 2 VTech InnoTab Max Camera Replacement: passo 3, immagine 2 di 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    4. VTech InnoTab Max Camera Replacement: passo 4, immagine 1 di 2 VTech InnoTab Max Camera Replacement: passo 4, immagine 2 di 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech InnoTab Max Camera Replacement, Camera: passo 5, immagine 1 di 1
      • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech InnoTab Max Camera Replacement: passo 6, immagine 1 di 2 VTech InnoTab Max Camera Replacement: passo 6, immagine 2 di 2
      • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
      • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
      Chiedi a FixBot
      Aggiungi Commento
    3. VTech InnoTab Max Camera Replacement: passo 7, immagine 1 di 1
      • The camera is now removed completely removed from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S5-G5, Lacy Spring 2017 Membro di USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Membri
35 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 865
