Salta al contenuto principale
VTech Baby's Learning Laptop Mouse Replacement
Cosa ti serve
  1. VTech Baby's Learning Laptop Mouse Replacement, Battery and Rear Panel: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
    Chiedi a FixBot
    Aggiungi Commento
  2. VTech Baby's Learning Laptop Mouse Replacement: passo 2, immagine 1 di 1
    • Remove the battery door.
    • Take out the batteries.
    Chiedi a FixBot
    Aggiungi Commento
  3. VTech Baby's Learning Laptop Mouse Replacement: passo 3, immagine 1 di 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
    Chiedi a FixBot
    Aggiungi Commento
  4. VTech Baby's Learning Laptop Mouse Replacement: passo 4, immagine 1 di 2 VTech Baby's Learning Laptop Mouse Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
    Chiedi a FixBot
    Aggiungi Commento
  5. VTech Baby's Learning Laptop Mouse Replacement, Mouse: passo 5, immagine 1 di 2 VTech Baby's Learning Laptop Mouse Replacement, Mouse: passo 5, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  6. VTech Baby's Learning Laptop Mouse Replacement: passo 6, immagine 1 di 3 VTech Baby's Learning Laptop Mouse Replacement: passo 6, immagine 2 di 3 VTech Baby's Learning Laptop Mouse Replacement: passo 6, immagine 3 di 3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
    Chiedi a FixBot
    Aggiungi Commento
  7. VTech Baby's Learning Laptop Mouse Replacement: passo 7, immagine 1 di 3 VTech Baby's Learning Laptop Mouse Replacement: passo 7, immagine 2 di 3 VTech Baby's Learning Laptop Mouse Replacement: passo 7, immagine 3 di 3
    • Locate and remove the following screws:
    • Two 11.0mm Phillips #2.
    • Two 7.3mm Phillips #0.
    • Remove the top of the mouse which will separate from the under side once the screws are removed.
    • The metal connection near the yellow screws on the top left of the mouse assembly falls out very easily. Make sure to replace the metal connection with the prong pointing up. Otherwise, the mouse will not work correctly.
    Chiedi a FixBot
    Aggiungi Commento
  8. VTech Baby's Learning Laptop Mouse Replacement: passo 8, immagine 1 di 2 VTech Baby's Learning Laptop Mouse Replacement: passo 8, immagine 2 di 2
    • Lift the springs up from the screw pegs with a plastic opening tool.
    • Remove the final part of the mouse.
    • Before reassembly, see the note on the previous step.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Justin Schanze
Membro da: 09/03/15
266 Reputazione
Una guida realizzata
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro di USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 61
Tutti i Tempi: 1,667
