Salta al contenuto principale
VENSTAR Taco Microphone Replacement Replacement
Cosa ti serve
  1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 1 di 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 2 di 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, immagine 3 di 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. VENSTAR Taco Microphone Replacement Replacement: passo 2, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 2, immagine 2 di 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
    Chiedi a FixBot
    Aggiungi Commento
  3. VENSTAR Taco Microphone Replacement Replacement: passo 3, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 3, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Phillips #0 Screwdriver
    $5.49
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    Chiedi a FixBot
    Aggiungi Commento
  4. VENSTAR Taco Microphone Replacement Replacement: passo 4, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 4, immagine 2 di 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    Chiedi a FixBot
    Aggiungi Commento
  5. VENSTAR Taco Microphone Replacement Replacement: passo 5, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 5, immagine 2 di 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    Chiedi a FixBot
    Aggiungi Commento
  6. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: passo 6, immagine 1 di 1
    • Remove the rubber covering from the buttons.
    Chiedi a FixBot
    Aggiungi Commento
  7. VENSTAR Taco Microphone Replacement Replacement: passo 7, immagine 1 di 3 VENSTAR Taco Microphone Replacement Replacement: passo 7, immagine 2 di 3 VENSTAR Taco Microphone Replacement Replacement: passo 7, immagine 3 di 3
    • Remove the black fabric covering the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  8. VENSTAR Taco Microphone Replacement Replacement: passo 8, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 8, immagine 2 di 2
    • Move the battery out of the way of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. VENSTAR Taco Microphone Replacement Replacement: passo 9, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement: passo 9, immagine 2 di 2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  10. VENSTAR Taco Microphone Replacement Replacement: passo 10, immagine 1 di 1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  11. VENSTAR Taco Microphone Replacement Replacement: passo 11, immagine 1 di 3 VENSTAR Taco Microphone Replacement Replacement: passo 11, immagine 2 di 3 VENSTAR Taco Microphone Replacement Replacement: passo 11, immagine 3 di 3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
    Chiedi a FixBot
    Aggiungi Commento
  12. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: passo 12, immagine 1 di 2 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: passo 12, immagine 2 di 2
    • Below the logic board, the small black microphone is resting within the case.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 37
Tutti i Tempi: 464
