Salta al contenuto principale
Upper Ice Maker Assembly Replacement
Cosa ti serve
  1. Upper Ice Maker Assembly Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 1 di 3 Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 2 di 3 Upper Ice Maker Assembly Replacement, Open the doors: passo 2, immagine 3 di 3
    • Open both refrigerator doors fully.
  3. Upper Ice Maker Assembly Replacement, Open the ice maker door: passo 3, immagine 1 di 3 Upper Ice Maker Assembly Replacement, Open the ice maker door: passo 3, immagine 2 di 3 Upper Ice Maker Assembly Replacement, Open the ice maker door: passo 3, immagine 3 di 3
    • Pull down the latch handle to release the ice maker door.
    • Swing open the ice maker door.
  4. Upper Ice Maker Assembly Replacement, Remove the ice bucket: passo 4, immagine 1 di 3 Upper Ice Maker Assembly Replacement, Remove the ice bucket: passo 4, immagine 2 di 3 Upper Ice Maker Assembly Replacement, Remove the ice bucket: passo 4, immagine 3 di 3
    • Using two hands, lift up the ice bucket slightly to release it.
    • Pull the bottom edge of the ice bucket toward you slightly and remove it.
  5. Upper Ice Maker Assembly Replacement, Reassembly notes: passo 5, immagine 1 di 3 Upper Ice Maker Assembly Replacement, Reassembly notes: passo 5, immagine 2 di 3 Upper Ice Maker Assembly Replacement, Reassembly notes: passo 5, immagine 3 di 3
    • The drive hub notches and drive blade wings must line up before installing the ice bucket.
    • Rotate the ice bucket hub, located on the rear of the ice bucket, with your hand so that the notches will align with the auger motor drive blades.
  6. Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: passo 6, immagine 1 di 2 Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: passo 6, immagine 2 di 2
    • Use a #2 Philips driver to remove the three 15 mm‑long screws that secure the ice maker assembly to the refrigerator door.
  7. Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 7, immagine 1 di 3 Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 7, immagine 2 di 3 Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: passo 7, immagine 3 di 3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  8. Upper Ice Maker Assembly Replacement: passo 8, immagine 1 di 3 Upper Ice Maker Assembly Replacement: passo 8, immagine 2 di 3 Upper Ice Maker Assembly Replacement: passo 8, immagine 3 di 3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  9. Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: passo 9, immagine 1 di 1
    • Remove the ice maker assembly.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro da: 06/30/22
38.579 Reputazione
261 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 172
