Salta al contenuto principale
UTStarcom CDM8945vw Keyboard Replacement
Cosa ti serve
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
    Chiedi a FixBot
    Aggiungi Commento
  2. UTStarcom CDM8945vw Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: passo 3, immagine 1 di 1
    • Identify the antenna. It is the extendable plastic component pictured here.
    Chiedi a FixBot
    Aggiungi Commento
  4. UTStarcom CDM8945vw Keyboard Replacement: passo 4, immagine 1 di 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
    Chiedi a FixBot
    Aggiungi Commento
  5. UTStarcom CDM8945vw Keyboard Replacement: passo 5, immagine 1 di 2 UTStarcom CDM8945vw Keyboard Replacement: passo 5, immagine 2 di 2
    • The antenna should slide right out of the phone when finished.
    Chiedi a FixBot
    Aggiungi Commento
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: passo 6, immagine 1 di 1
    • Remove the small rubber grommet using the plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  7. UTStarcom CDM8945vw Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove five screws using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. UTStarcom CDM8945vw Keyboard Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
    Chiedi a FixBot
    Aggiungi Commento
  9. UTStarcom CDM8945vw Keyboard Replacement: passo 9, immagine 1 di 1
    • Remove the back piece of the outer case.
    Chiedi a FixBot
    Aggiungi Commento
  10. UTStarcom CDM8945vw Keyboard Replacement: passo 10, immagine 1 di 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. UTStarcom CDM8945vw Keyboard Replacement: passo 11, immagine 1 di 2 UTStarcom CDM8945vw Keyboard Replacement: passo 11, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: passo 12, immagine 1 di 1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  13. UTStarcom CDM8945vw Keyboard Replacement: passo 13, immagine 1 di 2 UTStarcom CDM8945vw Keyboard Replacement: passo 13, immagine 2 di 2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: passo 14, immagine 1 di 1
    • Remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Bryon Hazlewood
Membro da: 10/03/12
1 Reputazione
2 guide realizzate
Cal Poly, Team 24-26, Regan Fall 2012 Membro di Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 11
Tutti i Tempi: 506
