Salta al contenuto principale
Turtle Beach REACT-R Vibration Motors Replacement
Cosa ti serve
  1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, immagine 1 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, immagine 2 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: passo 1, immagine 3 di 3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
    Chiedi a FixBot
    Aggiungi Commento
  2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, immagine 1 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, immagine 2 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: passo 2, immagine 3 di 3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
    Chiedi a FixBot
    Aggiungi Commento
  3. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, immagine 1 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, immagine 2 di 3 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: passo 3, immagine 3 di 3
    • Be careful not to damage the vibration motors by dangling the wires.
    • Place the motherboard down on its back.
    • Grip white rumble motor connector and pull it directly out of its socket to disconnect it from the motherboard. Repeat for the other motor.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 427
