Salta al contenuto principale
Tungsten E Disassembly
Cosa ti serve
    1. Tungsten E Disassembly, Tungsten E Disassembly: passo 1, immagine 1 di 2 Tungsten E Disassembly, Tungsten E Disassembly: passo 1, immagine 2 di 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Chiedi a FixBot
      Aggiungi Commento
    2. Tungsten E Disassembly: passo 2, immagine 1 di 3 Tungsten E Disassembly: passo 2, immagine 2 di 3 Tungsten E Disassembly: passo 2, immagine 3 di 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Chiedi a FixBot
      Aggiungi Commento
    3. Tungsten E Disassembly: passo 3, immagine 1 di 2 Tungsten E Disassembly: passo 3, immagine 2 di 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Chiedi a FixBot
      Aggiungi Commento
    4. Tungsten E Disassembly: passo 4, immagine 1 di 2 Tungsten E Disassembly: passo 4, immagine 2 di 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Chiedi a FixBot
      Aggiungi Commento
    5. Tungsten E Disassembly: passo 5, immagine 1 di 3 Tungsten E Disassembly: passo 5, immagine 2 di 3 Tungsten E Disassembly: passo 5, immagine 3 di 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Chiedi a FixBot
      Aggiungi Commento
    6. Tungsten E Disassembly: passo 6, immagine 1 di 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Kevin Hom
Membro da: 01/21/10
118 Reputazione
2 guide realizzate
Cal Poly, Team 13-22, Maness Winter 2010 Membro di Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Membri
12 guide realizzate
1Commento della guida
How does one unplug the battery?
dlcatftwin - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 50
Tutti i Tempi: 8,584
