Salta al contenuto principale
Trio AXS 3G Screen Replacement
Cosa ti serve
    1. Trio AXS 3G Screen Replacement, Back Case: passo 1, immagine 1 di 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Trio AXS 3G Screen Replacement: passo 2, immagine 1 di 2 Trio AXS 3G Screen Replacement: passo 2, immagine 2 di 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Chiedi a FixBot
      Aggiungi Commento
    3. Trio AXS 3G Screen Replacement: passo 3, immagine 1 di 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Chiedi a FixBot
      Aggiungi Commento
    1. Trio AXS 3G Screen Replacement, Screen: passo 4, immagine 1 di 1
      • The motherboard and battery will have to be removed to expose the metal panel underneath.
      Chiedi a FixBot
      Aggiungi Commento
    2. Trio AXS 3G Screen Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      Plastic Cards
      $2.99
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
      Chiedi a FixBot
      Aggiungi Commento
    3. Trio AXS 3G Screen Replacement: passo 6, immagine 1 di 1
      • Peel off the battery from the device and set aside.
      • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
      Chiedi a FixBot
      Aggiungi Commento
    4. Trio AXS 3G Screen Replacement: passo 7, immagine 1 di 1
      • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Trio AXS 3G Screen Replacement: passo 8, immagine 1 di 1
      • Disconnect the silver tape that attaches the motherboard to the metal panel.
      Chiedi a FixBot
      Aggiungi Commento
    6. Trio AXS 3G Screen Replacement: passo 9, immagine 1 di 1
      • Disconnect the ribbon from the bottom portion of the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    7. Trio AXS 3G Screen Replacement: passo 10, immagine 1 di 1
      • Remove the motherboard and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    8. Trio AXS 3G Screen Replacement: passo 11, immagine 1 di 1
      • The smaller portion of the motherboard is located at the bottom with the speaker.
      • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    9. Trio AXS 3G Screen Replacement: passo 12, immagine 1 di 2 Trio AXS 3G Screen Replacement: passo 12, immagine 2 di 2
      • Located towards the bottom, carefully remove the yellow film.
      Chiedi a FixBot
      Aggiungi Commento
    10. Trio AXS 3G Screen Replacement: passo 13, immagine 1 di 1
      • Gently disconnect the small ribbon found underneath the film.
      Chiedi a FixBot
      Aggiungi Commento
    11. Trio AXS 3G Screen Replacement: passo 14, immagine 1 di 1
      • There is another connection found underneath this portion of the motherboard.
      • Lifting up the motherboard, disconnect the second ribbon found underneath.
      Chiedi a FixBot
      Aggiungi Commento
    12. Trio AXS 3G Screen Replacement: passo 15, immagine 1 di 1
      • Unscrew the two 4 mm #000 screws.
      Chiedi a FixBot
      Aggiungi Commento
    13. Trio AXS 3G Screen Replacement: passo 16, immagine 1 di 1
      • Remove the speaker and bottom portion of the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    14. Trio AXS 3G Screen Replacement: passo 17, immagine 1 di 1
      • At this stage, almost all inside components should be removed (as shown).
      • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
      Chiedi a FixBot
      Aggiungi Commento
    15. Trio AXS 3G Screen Replacement: passo 18, immagine 1 di 3 Trio AXS 3G Screen Replacement: passo 18, immagine 2 di 3 Trio AXS 3G Screen Replacement: passo 18, immagine 3 di 3
      • Use the plastic card to separate the metal panel from the screen component.
      Chiedi a FixBot
      Aggiungi Commento
    16. Trio AXS 3G Screen Replacement: passo 19, immagine 1 di 1
      • Separate memory card from screen.
      Chiedi a FixBot
      Aggiungi Commento
    17. Trio AXS 3G Screen Replacement: passo 20, immagine 1 di 2 Trio AXS 3G Screen Replacement: passo 20, immagine 2 di 2
      • Use the plastic card to separate screen component from front panel.
      Chiedi a FixBot
      Aggiungi Commento
    18. Trio AXS 3G Screen Replacement: passo 21, immagine 1 di 1
      • Use the plastic card to separate the glass from the front panel.
      • Once the glass is removed, the new glass can be fitted to the front panel.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 1,336
