Salta al contenuto principale
Toshiba Tecra Z50-A Battery Replacement
Cosa ti serve
  1. Toshiba Tecra Z50-A Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Battery Replacement: passo 2, immagine 1 di 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Battery Replacement: passo 4, immagine 1 di 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Battery Replacement: passo 5, immagine 1 di 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Battery Replacement: passo 6, immagine 1 di 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Battery Replacement: passo 7, immagine 1 di 1
    • Lift up on the battery with your hands and remove it from the laptop.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Membro di UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 907
