Salta al contenuto principale
Toshiba Satellite U840W 12V Charging Port Replacement
Cosa ti serve
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: passo 1, immagine 1 di 2 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: passo 1, immagine 2 di 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, immagine 1 di 3 Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, immagine 2 di 3 Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, immagine 3 di 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, immagine 1 di 3 Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, immagine 2 di 3 Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, immagine 3 di 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: passo 6, immagine 1 di 1
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: passo 7, immagine 1 di 1
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: passo 8, immagine 1 di 1
    • Remove the 12v charging port from the cover.
Conclusione
Altre 2 persone hanno completato questa guida.
Gateway, Team S1-G1, Saknee Spring 2019 Membro di Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 271
