Salta al contenuto principale
Toshiba Encore Mini Front-Facing Camera Replacement
Cosa ti serve
    1. Toshiba Encore Mini Front-Facing Camera Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement, Battery: passo 1, immagine 2 di 2
      • To replace the battery, the rear cover must first be removed.
      • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
      • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
      Chiedi a FixBot
      Aggiungi Commento
    2. Toshiba Encore Mini Front-Facing Camera Replacement: passo 2, immagine 1 di 1
      • Remove the rear cover and set it aside.
      Chiedi a FixBot
      Aggiungi Commento
    3. Toshiba Encore Mini Front-Facing Camera Replacement: passo 3, immagine 1 di 1
      • Carefully remove the electrical tape that holds the battery in place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Toshiba Encore Mini Front-Facing Camera Replacement: passo 4, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement: passo 4, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
      Chiedi a FixBot
      Aggiungi Commento
    5. Toshiba Encore Mini Front-Facing Camera Replacement: passo 5, immagine 1 di 1
      • Gently lift the battery out of the device.
      • Be careful not to pull on the connecting wires.
      Chiedi a FixBot
      Aggiungi Commento
    1. Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 1 di 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 2 di 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: passo 6, immagine 3 di 3
      • The audio module must be removed to replace the front-facing camera.
      • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
      • Gently remove red/black wire strands from the clips holding them to the back of the screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Toshiba Encore Mini Front-Facing Camera Replacement: passo 7, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement: passo 7, immagine 2 di 2
      • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
      • Adhesive on the bottom of the speaker module may make it difficult to remove.
      • Set the audio module and attached wire aside.
      Chiedi a FixBot
      Aggiungi Commento
    3. Toshiba Encore Mini Front-Facing Camera Replacement: passo 8, immagine 1 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 8, immagine 2 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 8, immagine 3 di 3
      • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
      • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
      Chiedi a FixBot
      Aggiungi Commento
    4. Toshiba Encore Mini Front-Facing Camera Replacement: passo 9, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement: passo 9, immagine 2 di 2
      • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
      • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Toshiba Encore Mini Front-Facing Camera Replacement: passo 10, immagine 1 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 10, immagine 2 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 10, immagine 3 di 3
      • Damaging this ribbon will permanently disable your device!
      • Using needle-nose tweezers, carefully flip up the dark gray cover.
      • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
      Chiedi a FixBot
      Aggiungi Commento
    6. Toshiba Encore Mini Front-Facing Camera Replacement: passo 11, immagine 1 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 11, immagine 2 di 3 Toshiba Encore Mini Front-Facing Camera Replacement: passo 11, immagine 3 di 3
      • Using a Phillips 000 screwdriver, remove the screws holding components together.
      • Remove four 4.2 mm Phillips screws.
      • Remove one 3mm Phillips screw.
      Chiedi a FixBot
      Aggiungi Commento
    7. Toshiba Encore Mini Front-Facing Camera Replacement: passo 12, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement: passo 12, immagine 2 di 2
      • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
      • The motherboard may resist as you try to lift it --this is normal.
      Chiedi a FixBot
      Aggiungi Commento
    8. Toshiba Encore Mini Front-Facing Camera Replacement: passo 13, immagine 1 di 2 Toshiba Encore Mini Front-Facing Camera Replacement: passo 13, immagine 2 di 2
      • The front-facing camera may dislodge freely when removing the motherboard.
      • If camera has not already "popped" off the motherboard, use needle-nose tweezers to gently grasp the camera and remove from motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Shirley Low
Membro da: 07/09/15
143 Reputazione
Una guida realizzata
UW Tacoma, Team 1-3, Liner SU 2015 Membro di UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 23
Tutti i Tempi: 719
