Salta al contenuto principale
Top Cover
Cosa ti serve
    1. Top Cover, Remove screws: passo 1, immagine 1 di 1
      • Remove six Philips #2 screws from the bottom of the case.
      • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
      Chiedi a FixBot
      Aggiungi Commento
    2. Top Cover, Disconnect top cover ribbon cable: passo 2, immagine 1 di 1
      • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
      • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
      • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
      Chiedi a FixBot
      Aggiungi Commento
    3. Top Cover, Remove RF shield: passo 3, immagine 1 di 2 Top Cover, Remove RF shield: passo 3, immagine 2 di 2
      • Simply lift the RF shield off the unit.
      • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Matt Falcon
Membro da: 05/09/15
2.800 Reputazione
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 314
