Salta al contenuto principale
TomTom One XL Screen Replacement
Cosa ti serve
  1. TomTom One XL Screen Replacement, Back Panel: passo 1, immagine 1 di 2 TomTom One XL Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the 4 .4mm screws on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. TomTom One XL Screen Replacement: passo 2, immagine 1 di 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    Chiedi a FixBot
    Aggiungi Commento
  3. TomTom One XL Screen Replacement: passo 3, immagine 1 di 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    Chiedi a FixBot
    Aggiungi Commento
  4. TomTom One XL Screen Replacement: passo 4, immagine 1 di 2 TomTom One XL Screen Replacement: passo 4, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    Chiedi a FixBot
    Aggiungi Commento
  5. TomTom One XL Screen Replacement, Screen: passo 5, immagine 1 di 2 TomTom One XL Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Locate the 4 .4mm screws connecting the circuit board to the front panel.
    • Use the T6 Torx screwdriver and remove the four screws.
    Chiedi a FixBot
    Aggiungi Commento
  6. TomTom One XL Screen Replacement: passo 6, immagine 1 di 3 TomTom One XL Screen Replacement: passo 6, immagine 2 di 3 TomTom One XL Screen Replacement: passo 6, immagine 3 di 3
    • Locate the ribbon cable connecting the front panel to the circuit board.
    • Locate the white tab locking the ribbon in place.
    • Using precision tweezers push the left and right side of the tab forward.
    • Gently pull the ribbon to disconnect the circuit board from the front panel.
    • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
    Chiedi a FixBot
    Aggiungi Commento
  7. TomTom One XL Screen Replacement: passo 7, immagine 1 di 3 TomTom One XL Screen Replacement: passo 7, immagine 2 di 3 TomTom One XL Screen Replacement: passo 7, immagine 3 di 3
    • Use the palate knife to pry the screen away from the front panel.
    • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
    • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
DeVhan
Membro da: 03/11/15
401 Reputazione
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 1,241
