Salta al contenuto principale
TomTom One XL Power Button Replacement
Cosa ti serve
  1. TomTom One XL Power Button Replacement, Back Panel: passo 1, immagine 1 di 2 TomTom One XL Power Button Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the 4 .4mm screws on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. TomTom One XL Power Button Replacement: passo 2, immagine 1 di 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    Chiedi a FixBot
    Aggiungi Commento
  3. TomTom One XL Power Button Replacement: passo 3, immagine 1 di 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    Chiedi a FixBot
    Aggiungi Commento
  4. TomTom One XL Power Button Replacement: passo 4, immagine 1 di 2 TomTom One XL Power Button Replacement: passo 4, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    Chiedi a FixBot
    Aggiungi Commento
  5. TomTom One XL Power Button Replacement, Power Button: passo 5, immagine 1 di 1
    • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
    • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
    Chiedi a FixBot
    Aggiungi Commento
  6. TomTom One XL Power Button Replacement: passo 6, immagine 1 di 2 TomTom One XL Power Button Replacement: passo 6, immagine 2 di 2
    • Detach the ribbon wire from it's port on the back of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. TomTom One XL Power Button Replacement: passo 7, immagine 1 di 3 TomTom One XL Power Button Replacement: passo 7, immagine 2 di 3 TomTom One XL Power Button Replacement: passo 7, immagine 3 di 3
    • Now the power button is exposed and any obstructions can be easily removed.
    • If you want to replace the button it can easily be popped out using your hands.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Jesse
Membro da: 03/11/15
101 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 25
Tutti i Tempi: 2,584
