Salta al contenuto principale
ThinkPad T420 Memory Replacement
Cosa ti serve
  1. ThinkPad T420 Memory Replacement, Change note: passo 1, immagine 1 di 2 ThinkPad T420 Memory Replacement, Change note: passo 1, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Essential Electronics Toolkit
    $29.95
    • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
    • If you are interested in a refurbished kit stock levels change frequently but can be found here.
    Chiedi a FixBot
    Aggiungi Commento
  2. ThinkPad T420 Memory Replacement, Unlock the battery: passo 2, immagine 1 di 3 ThinkPad T420 Memory Replacement, Unlock the battery: passo 2, immagine 2 di 3 ThinkPad T420 Memory Replacement, Unlock the battery: passo 2, immagine 3 di 3
    • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
    • Unlock the latch locking the battery in the laptop.
    • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. ThinkPad T420 Memory Replacement, Release the battery: passo 3, immagine 1 di 3 ThinkPad T420 Memory Replacement, Release the battery: passo 3, immagine 2 di 3 ThinkPad T420 Memory Replacement, Release the battery: passo 3, immagine 3 di 3
    • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  4. ThinkPad T420 Memory Replacement, Remove the RAM door: passo 4, immagine 1 di 3 ThinkPad T420 Memory Replacement, Remove the RAM door: passo 4, immagine 2 di 3 ThinkPad T420 Memory Replacement, Remove the RAM door: passo 4, immagine 3 di 3
    • EET owners: Your kit has this bit. No purchase needed.
    • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
    • Pull the cover up with a fingernail or a nonmarring pry tool.
    • Remove the screw retaining the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. ThinkPad T420 Memory Replacement, Remove the keyboard: passo 5, immagine 1 di 3 ThinkPad T420 Memory Replacement, Remove the keyboard: passo 5, immagine 2 di 3 ThinkPad T420 Memory Replacement, Remove the keyboard: passo 5, immagine 3 di 3
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  6. ThinkPad T420 Memory Replacement, Disconnect the keyboard: passo 6, immagine 1 di 3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: passo 6, immagine 2 di 3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: passo 6, immagine 3 di 3
    • To reinstall the keyboard, refer to the steps in this guide.
    • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
    Chiedi a FixBot
    Aggiungi Commento
  7. ThinkPad T420 Memory Replacement, RAM module - Bottom: passo 7, immagine 1 di 3 ThinkPad T420 Memory Replacement, RAM module - Bottom: passo 7, immagine 2 di 3 ThinkPad T420 Memory Replacement, RAM module - Bottom: passo 7, immagine 3 di 3
    • Unclip the RAM module by pulling the memory retention tabs back.
    • Remove the existing module by pulling the module from the side, at a 90 degree angle.
    Chiedi a FixBot
    Aggiungi Commento
  8. ThinkPad T420 Memory Replacement, RAM module - keyboard: passo 8, immagine 1 di 3 ThinkPad T420 Memory Replacement, RAM module - keyboard: passo 8, immagine 2 di 3 ThinkPad T420 Memory Replacement, RAM module - keyboard: passo 8, immagine 3 di 3
    • Lift the plastic cover hiding the RAM module.
    • Unlatch the tabs retaining the memory module.
    • Pull the module out from a 90 degree angle.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
Nick
Membro da: 11/10/09
104.939 Reputazione
72 guide realizzate
Master Techs Membro di Master Techs
Community
333 Membri
1.694 guide realizzate
2Commenti sulla guida
What tool might one use as a pry?
commander - Rispondi Condividi
The plastic pry tool will also work for the bottom RAM/mSATA part. I can usually get it open without the assistance of pry tools.
Nick - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 25
Ultimi 30 giorni: 133
Tutti i Tempi: 22,000
