Salta al contenuto principale
ThinkPad Edge E31 Wireless Card Replacement
Cosa ti serve
  1. ThinkPad Edge E31 Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Chiedi a FixBot
    Aggiungi Commento
  2. ThinkPad Edge E31 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. ThinkPad Edge E31 Wireless Card Replacement, ThinkPad Edge E31 Underside Disassembly: passo 3, immagine 1 di 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. ThinkPad Edge E31 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • The wireless card is located above the Hard drive and RAM on the exposed laptop.
    • There are 2, 4mm long M2 screws holding the wireless card to the laptop. Unscrew the screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. ThinkPad Edge E31 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Once the screws are removed, there will be 2 wires attached to the card. These can be easily popped off by hand to fully disconnect the card form the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Riley
Membro da: 03/19/17
601 Reputazione
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 8
Tutti i Tempi: 363
