Salta al contenuto principale
Texas Instruments TI-83 Plus Keyboard Mat Replacement
Cosa ti serve
  1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: passo 1, immagine 1 di 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: passo 1, immagine 2 di 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    Chiedi a FixBot
    Aggiungi Commento
  2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 2, immagine 1 di 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Back Case: passo 4, immagine 1 di 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    Chiedi a FixBot
    Aggiungi Commento
  5. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 5, immagine 1 di 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 5, immagine 2 di 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    Chiedi a FixBot
    Aggiungi Commento
  6. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: passo 6, immagine 1 di 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: passo 6, immagine 2 di 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 7, immagine 1 di 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 7, immagine 2 di 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
    Chiedi a FixBot
    Aggiungi Commento
  8. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: passo 8, immagine 1 di 2 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: passo 8, immagine 2 di 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Texas Instruments TI-83 Plus Keyboard Mat Replacement: passo 9, immagine 1 di 1
    • Clean the contacts on the keyboard with a soft cloth.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
corey
Membro da: 10/02/12
11 Reputazione
Una guida realizzata
Cal Poly, Team 18-37, Regan Fall 2012 Membro di Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 53
Tutti i Tempi: 5,156
