Salta al contenuto principale
Texas Instruments TI-83 Plus Individual Keys Replacement
Cosa ti serve
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: passo 1, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: passo 1, immagine 2 di 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    Chiedi a FixBot
    Aggiungi Commento
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: passo 2, immagine 1 di 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: passo 4, immagine 1 di 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    Chiedi a FixBot
    Aggiungi Commento
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: passo 5, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement: passo 5, immagine 2 di 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    Chiedi a FixBot
    Aggiungi Commento
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: passo 6, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: passo 6, immagine 2 di 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: passo 7, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement: passo 7, immagine 2 di 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
    Chiedi a FixBot
    Aggiungi Commento
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: passo 8, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: passo 8, immagine 2 di 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: passo 9, immagine 1 di 1
    • Clean the contacts on the keyboard with a soft cloth.
    Chiedi a FixBot
    Aggiungi Commento
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: passo 10, immagine 1 di 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: passo 10, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Jared
Membro da: 10/02/12
156 Reputazione
2 guide realizzate
Cal Poly, Team 18-37, Regan Fall 2012 Membro di Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 17
Ultimi 30 giorni: 59
Tutti i Tempi: 5,448
