Salta al contenuto principale
Tagital T10 Touch Screen Replacement
Cosa ti serve
    1. Tagital T10 Touch Screen Replacement, Touch Screen: passo 1, immagine 1 di 1
      • Always make sure your device is completely powered off before performing repairs
      • Remove the two 4mm screws at the top of the device.
      • Set these aside and be careful not to lose them, as well as all other screws that you remove.
      Chiedi a FixBot
      Aggiungi Commento
    2. Tagital T10 Touch Screen Replacement: passo 2, immagine 1 di 1
      • Carefully remove the back cover by using a plastic prying tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
      Chiedi a FixBot
      Aggiungi Commento
    3. Tagital T10 Touch Screen Replacement: passo 3, immagine 1 di 1
      • The display screen is the silver box that the battery and motherboard sit on. It sits snugly against the underside of the touch screen.
      • Remove all of the 4mm screws that attach the display screen to the back of the touch screen with brackets.
      Chiedi a FixBot
      Aggiungi Commento
    4. Tagital T10 Touch Screen Replacement: passo 4, immagine 1 di 2 Tagital T10 Touch Screen Replacement: passo 4, immagine 2 di 2
      • Remove all of the 4mm screws that attach the motherboard to the rest of the device.
      • One screw is located beneath the black tape that holds the rear-facing camera in place. Peel the tape up to access it.
      Chiedi a FixBot
      Aggiungi Commento
    5. Tagital T10 Touch Screen Replacement: passo 5, immagine 1 di 2 Tagital T10 Touch Screen Replacement: passo 5, immagine 2 di 2
      • Locate the 2 ZIF connectors.
      • Flip up the black tab to release the two filaments, so that they are no longer connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    6. Tagital T10 Touch Screen Replacement: passo 6, immagine 1 di 2 Tagital T10 Touch Screen Replacement: passo 6, immagine 2 di 2
      • Locate the notification light on the upper left corner of the device.
      • Gently pull on the wires to remove the light from its housing.
      Chiedi a FixBot
      Aggiungi Commento
    7. Tagital T10 Touch Screen Replacement: passo 7, immagine 1 di 1
      • Remove the motherboard from the back of the display screen.
      • Some wires are still attached to the device so carefully set it to the side
      Chiedi a FixBot
      Aggiungi Commento
    8. Tagital T10 Touch Screen Replacement: passo 8, immagine 1 di 2 Tagital T10 Touch Screen Replacement: passo 8, immagine 2 di 2
      • Begin lifting the display screen out of its housing with a plastic prying tool, sliding it around the perimeter of the screen.
      • It may be helpful to use two prying tools at the same time.
      Chiedi a FixBot
      Aggiungi Commento
    9. Tagital T10 Touch Screen Replacement: passo 9, immagine 1 di 1
      • Completely remove the display screen from the touchscreen.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Jessalyn Aretz
Membro da: 09/26/16
212 Reputazione
Una guida realizzata
USF Tampa, Team 14-5, Eyestone Fall 2016 Membro di USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 22
Tutti i Tempi: 1,765
