Salta al contenuto principale
SwagTron T1 Gyroscope Replacement
Cosa ti serve
    1. SwagTron T1 Gyroscope Replacement, Back Panels: passo 1, immagine 1 di 1
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      Chiedi a FixBot
      Aggiungi Commento
    2. SwagTron T1 Gyroscope Replacement: passo 2, immagine 1 di 3 SwagTron T1 Gyroscope Replacement: passo 2, immagine 2 di 3 SwagTron T1 Gyroscope Replacement: passo 2, immagine 3 di 3
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      Chiedi a FixBot
      Aggiungi Commento
    3. SwagTron T1 Gyroscope Replacement: passo 3, immagine 1 di 3 SwagTron T1 Gyroscope Replacement: passo 3, immagine 2 di 3 SwagTron T1 Gyroscope Replacement: passo 3, immagine 3 di 3
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      Chiedi a FixBot
      Aggiungi Commento
    1. SwagTron T1 Gyroscope Replacement, Gyroscope: passo 4, immagine 1 di 2 SwagTron T1 Gyroscope Replacement, Gyroscope: passo 4, immagine 2 di 2
      • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
      Chiedi a FixBot
      Aggiungi Commento
    2. SwagTron T1 Gyroscope Replacement: passo 5, immagine 1 di 1
      • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
      Chiedi a FixBot
      Aggiungi Commento
    3. SwagTron T1 Gyroscope Replacement: passo 6, immagine 1 di 3 SwagTron T1 Gyroscope Replacement: passo 6, immagine 2 di 3 SwagTron T1 Gyroscope Replacement: passo 6, immagine 3 di 3
      • Carefully remove the gyroscope component from the SwagTron.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro di Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Membri
15 guide realizzate
5Commenti sulla guida
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Rispondi Condividi
Amazon.com Keyword: CertiCable
Jesse Griffis - Rispondi Condividi
Where do you get the replacement?
Brittany Conner - Rispondi Condividi
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Rispondi Condividi
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 14
Ultimi 30 giorni: 64
Tutti i Tempi: 8,386
